It is currently Tue Sep 29, 2026 8:21 am
 Post subject: Power steering delete
PostPosted: Mon Nov 01, 2004 7:58 pm
I figured I would just take the whole system out, since I wasn't using it. ;)
http://fbodyeurope.org/gallery/11_P1020243.JPG
PostPosted: Mon Nov 01, 2004 8:46 pm
Jack,
what did you do with the EGR Pipe?
PostPosted: Mon Nov 01, 2004 8:58 pm
You need another plate to go there now :wink:
PostPosted: Mon Nov 01, 2004 10:03 pm
I know, but they don't make them. I wonder if I could get another one, and just turn it around. Hmm.
Vadim, I took all that out a couple years ago, and used LS1Edit to complete the deinstallation. ;)
PostPosted: Tue Nov 02, 2004 11:57 am
Cool, what's the gain? Weight or smth more?
Is there any change in polution or smth?
PostPosted: Tue Nov 02, 2004 1:17 pm
Well, the '01s and '02s don't come with it, so that's why I removed it. It's probably mostly just a weight reducer, but it also cleans up the engine bay quite a bit.
PostPosted: Tue Nov 02, 2004 1:23 pm
nice...
I would like to remove it too. Do you have a "how to do" link? Or anything I should watch out? How did you close the hole on the intake?
PostPosted: Tue Nov 02, 2004 2:36 pm
I got a block off plate from Nineball on LS1Tech. Now you can get a nice billet one on Ebay. All you do is remove the part that goes in between the exhaust manifolds. It is really easy, but you will have to fabricate or buy the manifold EGR block off plates also.
PostPosted: Tue Nov 02, 2004 3:03 pm
Jack, did you stock up on replacement steering wheels btw.? :lol:
PostPosted: Tue Nov 02, 2004 3:34 pm
Well I have one from a 3rd gen, minus the airbag assembly, and one from a 2nd gen, I think! :)
