It is currently Fri Oct 23, 2026 9:36 am
 Post subject: exhaust cut-outs legal?
PostPosted: Tue Jun 12, 2007 9:36 pm
Can we pass inspection with cut-outs?
I added a Moroso Spiral flow to my exhaust to bring the noise down, now it sounds like a normal V8. It's not bad, but definitely not very mean :( I'll try to get it dyno'd again to see what affect it has, but I'm thinking about adding an electric exhaust cut-out to get some ponies back when I want them.
PostPosted: Tue Jun 12, 2007 9:51 pm
brianterry had one on his T/A, when closed it channeled the gasses thru the muffler, when it was open, it went straight out....as long as it's closed and doesnt leak, I dont think you will have an issue
PostPosted: Tue Jun 12, 2007 9:56 pm
Thats a darn good question. I have not heard of anyone having problems passing with one. However, I have read the inspection regulation and it so no cutouts can be used. I will probably be testing that reg in the next few months so let me know how it goes :D .
PostPosted: Sun Jun 24, 2007 9:58 pm
Bringing this back from the dead.
I've tried looking for the inspection regs, I had links saved but they no longer work. Anybody have good links? Is it AER 190-1?
PostPosted: Mon Jun 25, 2007 3:27 am
http://rmv.hqusareur.army.mil/190-1/190-1.pdf
PostPosted: Mon Jun 25, 2007 7:09 pm
Thanks. Apparently my internet connection just sucks. Every time I try and download a file, my connection gets re-set. :evil:
PostPosted: Mon Jun 25, 2007 8:56 pm
It says no cut-outs, but I have not heard of anyone failing yet. I'll be able to tell you in about a month!
PostPosted: Tue Jun 26, 2007 6:33 pm
Cool, I guess I can wait a month :) I don't have much room left on my I-pipe so I'm thinking about placing one where the pipe turns to the muffler.
PostPosted: Tue Jun 26, 2007 6:56 pm
It may be a bit longer because it is shipping from the states. I will let you know though.
Did you get your pinion angle guage?
PostPosted: Wed Jun 27, 2007 5:16 pm
Ok, so it already has a cut-out and this will be it's first inspection?
PostPosted: Thu Jun 28, 2007 2:58 am
Yeah, its an electric one already fixed in place of the Borla plates. I am hoping they will miss it or I can hide it :twisted:
PostPosted: Thu Jun 28, 2007 8:47 am
You could just swap it out with the Borla plate (without the hole) and it will be all good and quiet enough I guess.
PostPosted: Sun Jul 01, 2007 6:19 pm
It shouldn't be very noticable with the Borla set-up. I should have just bought one of those instead of adding a bullet muffler :(
 Post subject: Hey A10
PostPosted: Thu Oct 04, 2007 6:05 am
Did you get these on? Did everything pass?
02 Ford Mustang GT Vert
PostPosted: Fri Oct 05, 2007 4:45 am
I still have not received my car yet to gfind out. I should be down to the next couple of weeks as it is due in Germany on the 10th!
