It is currently Fri Oct 23, 2026 7:25 am
 Post subject: Wide Band O2
PostPosted: Sun Oct 28, 2007 8:16 pm
This is a dumb question, but is there a way to visually tell the difference between a standard and wide band O2?
I think my new car may have one and I am trying to figure out if it is. I cannot tell the difference from the standard O2's
PostPosted: Sun Oct 28, 2007 8:21 pm
does it have any markings?
most WBO2 will have an external controller in order to be able to hook them up to a motor expecting a NBO2 ...
PostPosted: Sun Oct 28, 2007 9:01 pm
There is only 1 in the driver side of the Y-pipe. It is not connected. That is what caught my attention. As far as I could tell, there were no markings on it. It looked just like the other 2.
PostPosted: Sun Oct 28, 2007 9:25 pm
In the Y-pipe? Before or after the cats?
PostPosted: Sun Oct 28, 2007 9:30 pm
In the Y-pipe. Its uhhhhhhh............after the cats if there were any.
PostPosted: Sun Oct 28, 2007 9:52 pm
Hm ... WB BEHIND cats doesn't make sense ...
Anyway, w/o controller and w/o being connected, it won't do much good ;)
PostPosted: Mon Oct 29, 2007 12:14 am
a wideband allways has 5 wires ..
you MUST hook the wideband up to a (wideband) controller if your engine is running otherwise the sensor goes bad very fast
PostPosted: Mon Oct 29, 2007 5:43 am
IIRC, the LC1 Bosch Sensor only has 4 ... but the WB Controller has quite a few more than 5 ... ;)
PostPosted: Mon Oct 29, 2007 6:06 am
This one has 4 wires. Hmmm. No biggie.
Thanks
PostPosted: Mon Oct 29, 2007 9:28 am
you absolutely sure Garry ?
i'll have a look today :shock:
Users browsing this forum: No registered users and 33 guests
