It is currently Sat Oct 24, 2026 1:59 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 10 posts ]
Which theme/style would you prefer to use? (select up to two styles)
Arrow 0%  0%  [ 0 ]
Carbon 25%  25%  [ 2 ]
Speed 0%  0%  [ 0 ]
Echotech 0%  0%  [ 0 ]
Odyssey 13%  13%  [ 1 ]
darksunblue 63%  63%  [ 5 ]
they all suck ... 0%  0%  [ 0 ]
Total votes : 8
 Post subject: IMPORTANT! Theme/Style Poll ...
PostPosted: Sun Dec 23, 2007 11:08 am
After going through adding mods to a style, and seeing (as expected) what PITA it can be, I'd appreciate some kind of feedback on what style you would most likely use ... as mentioned before, I've already added a couple different styles that are somewhat similar to the old style, though I have not modified the graphics that come with the style ... point is to first decide on a general look, then additional work can be put in ...
I'll take one, maybe even two styles for the final look ... they will get any mods that are installed ... the other styles will most likely remain, but won't necessarily get altered with additional features ...
If you don't like any at all, give some feedback, too ... there are lots of pre-built styles out there already (you can check in the Community-section of phpbb.com ...), so adding alternate styles isn't really much of a problem ...
 Post subject: Re: IMPORTANT! Theme/Style Poll ...
PostPosted: Sun Dec 23, 2007 12:20 pm
Dark sun blue
PostPosted: Sun Dec 23, 2007 2:16 pm
Actually contrary to what I said before, my favorite has also become "dark sun blue".
PostPosted: Sun Dec 23, 2007 4:51 pm
Garry....
maybe I'm over looking it but how do i veiw the other styles your refuring to?
PostPosted: Sun Dec 23, 2007 4:58 pm
98blkbrd wrote:
Garry....
Go to the User Control Panel (called "UserCP" on some styles), Board Preferences.
PostPosted: Sun Dec 23, 2007 9:33 pm
Dark Sun Blue but wiht a different background other than black.
PostPosted: Sun Dec 23, 2007 9:34 pm
What do you have in mind? Something like this?
PostPosted: Mon Dec 24, 2007 9:22 am
Just added the "Quick Reply" to darksunblue, also polished up all of the buttons to have a clear frame, which was necessary for a changed background color ..
PostPosted: Thu Jan 10, 2008 5:43 am
Guess this topic is more or less settled ... ;)
PostPosted: Fri Jan 11, 2008 2:18 pm
Yep I believe it is Garry.
Users browsing this forum: No registered users and 12 guests
