It is currently Wed Sep 09, 2026 10:33 am
 Post subject: 1979 firebird
PostPosted: Fri Nov 05, 2004 9:53 pm
What kind of transmission do you guys think I should put in my 79 that I am going to get when I get back to states and where could I get one? Also do you think that I should get another 403 to put in it or should I go with like a 400 I want to get just a good medium engine that I can biuld later as I get more cash 8) and where would you recomend I go to get one
Pain is weakness leaving the body.
PostPosted: Sat Nov 06, 2004 1:29 am
also I am looking for door hinge bushings and the latch assembly I need for both doors if you guys know where maybe I can get some
PostPosted: Sat Nov 06, 2004 6:17 am
That's a hard one. What are you really wanting to do with this car? And where are you going in the states?
If its around Houston, Jack will need something to wrench on
PostPosted: Sat Nov 06, 2004 9:16 pm
I was just wanting something a little better than factory that I can fix up on slowly(due to money :( ) and eventually something that will pick the front tires up off the ground a little but not enough to need a wheelie bar and looks good enough that I could put it in some car shows and to the second question hopefully somewhere around Oklahoma Kansas area or nearby but dont know for sure yet
