| 16X8 wheels wanted http://forum.fbodyeurope.org/phpBB3/viewtopic.php?f=32&t=5195 |
Page 1 of 1 |
| Author: | JackZ28 [ Fri Dec 03, 2004 9:13 am ] |
| Post subject: | 16X8 wheels wanted |
Something cheap, that you will let go for no more than $100. The center hub hole for mine are a bit too big, and even if they're balanced, the car still shakes. |
| Author: | CandyMan [ Fri Dec 03, 2004 7:32 pm ] |
| Post subject: | |
Jack, did you buy some BMW wheels? If so, yes, the center hole is a lil bit too big, but you can buy some rings that make your wheel sit right |
| Author: | JackZ28 [ Fri Dec 03, 2004 8:31 pm ] |
| Post subject: | |
From where? I've never seen those. If you can get them, please let me know how much they are. |
| Author: | CandyMan [ Fri Dec 03, 2004 9:20 pm ] |
| Post subject: | |
any wheel/tire dealer should have them, Jack! |
| Author: | JackZ28 [ Fri Dec 03, 2004 10:00 pm ] |
| Post subject: | |
What's the German name for them? |
| Author: | CandyMan [ Fri Dec 03, 2004 10:01 pm ] |
| Post subject: | |
Zentrierringe. |
| Author: | JackZ28 [ Fri Dec 03, 2004 10:09 pm ] |
| Post subject: | |
Do you have to buy a bunch of thin ones, and use as many as you need, or do you tell them "I need one for Camaro-BMW? |
| Author: | CandyMan [ Fri Dec 03, 2004 10:15 pm ] |
| Post subject: | |
I don't know, I think it's better you drive somewhere and they see which ones fit. They have them in different sizes... |
| Author: | CandyMan [ Fri Dec 03, 2004 10:16 pm ] |
| Post subject: | |
or you just tell them the diameter of your center hub, then they must know... |
| Author: | JackZ28 [ Fri Dec 03, 2004 10:41 pm ] |
| Post subject: | |
I wonder why they didn't say anything about those at the balancing place. |
| Author: | CandyMan [ Fri Dec 03, 2004 10:46 pm ] |
| Post subject: | |
That's sad. But it's everywhere like that today. They just want money from you and dont give a chit if you crash bcoz of the wheels. |
| Author: | JackZ28 [ Fri Dec 03, 2004 10:50 pm ] |
| Post subject: | |
Well if they wanted money, they could have balanced the wheels, fixed the flat I asked them to, and finally they could have sold me the rings that I needed for the wheels. Strange. |
| Author: | CandyMan [ Fri Dec 03, 2004 10:56 pm ] |
| Post subject: | |
yeah, but what I wanted to say, is that they dont care or think. Don't Think but work like machines! |
| Author: | JackZ28 [ Fri Dec 03, 2004 10:58 pm ] |
| Post subject: | |
True! I'm sure they thought about the rings after I left. |
| Author: | jarek5_7 [ Sat Dec 04, 2004 1:17 am ] |
| Post subject: | |
the center rign cpuld be helpful but there is also a diffrence in size. bmw have 120 mm and camaro has 120.7 mm so the best way to mount wheels from bmw is to use "floating" type lugs |
