It is currently Wed Sep 09, 2026 10:33 am
 Post subject: Need a bolt ASAP
PostPosted: Tue May 10, 2005 4:59 pm
I need one of the bolts that hold the rear caliper to the caliper mounting plate. There are two of them and I have lost one and almost lost a second one!!!! I think the part number is 14067559 (M12-1.75X33.1). I am not sure of the part number just of where the little bastard goes.
Someone please assist!!!
TIA!
Larry
PostPosted: Tue May 10, 2005 5:18 pm
http://fbodyeurope.org/files/rcaliper.pdf - if you are talking about Part #14, your number should be right ... how can you lose those bolts? Guess you need to use more locktite ;)
PostPosted: Tue May 10, 2005 5:36 pm
You should be able to source that bolt through Wuerth industries. There should be an outlet in your area.
PostPosted: Tue May 10, 2005 5:57 pm
Garry, the bolt appears to be used in a couple of different locations. That is not where I lost on, I lost it off the bracket the caliper itself bolts on to... As far as how did I loose it, well lets just say I obviously did not torque the little bastard down good enough. Live and learn, at least IT was found before there was a severe problem.
Roy, I will see if I can find them, I was just hoping someone on the forum had built a bench stock of nuts and bolts. I am learning, it is time to build a bench stock. I can't believe how fast the hardware on these cars goes TU... I have broke a few bolts this year doing new part installs (old ones of course). :)
PostPosted: Tue May 10, 2005 6:40 pm
I believe this is the part number I am looking for: 10112649
PostPosted: Tue May 10, 2005 6:58 pm
Here is the address and phone number
Wuerth Montage
Strasse / Nr.: KÖLNER STR. 10
PLZ / Ort: 70376 STUTTGART
Land DEUTSCHLAND
Telefon: (0711) 9557320
I don't know if they are a Gross handler or not. But if they are sometimes the wearing the uniform works to get what you need.
PostPosted: Tue May 10, 2005 7:06 pm
Thanks Roy,
I am going to remove the one off the passenger lower side and just say "I need one of these" :lol:
