It is currently Wed Sep 09, 2026 11:29 am
 Post subject: Sway Bar connection rods (or whatever they may be called)
PostPosted: Mon Apr 02, 2007 5:12 am
Swapping sway bars & PH between Camaro and Firebird, the inevitable happened ... the stock rods tha connect the sway bar end links to the body on the Firebird were slightly ;) rusted, so out of the four rods, I was able to get one out that didn't break in the process ...
So I could use two sets of rods, one front, one rear ... anybody happen to have any take-offs flying around?
Otherwise, I will just see if I can pick up something similar here ...
PostPosted: Mon Apr 02, 2007 9:02 am
I snapped also all of them everytime i tried to remove them from a car, stopped when i replaced that endlinks with a set from energy suspension...
PostPosted: Mon Apr 02, 2007 9:03 am
The BMR ones were almost like new ... hardly any corrosion, no rust ... would have sucked if they too had snapped ... :(
PostPosted: Mon Apr 02, 2007 3:55 pm
I may have some. Remind me if I don't get back to you.
