| serpentine pulley 6 rib of pref. 8 rib steeringpump /crank http://forum.fbodyeurope.org/phpBB3/viewtopic.php?f=32&t=8342 |
Page 1 of 1 |
| Author: | jeejee [ Fri Feb 13, 2009 12:08 pm ] |
| Post subject: | serpentine pulley 6 rib of pref. 8 rib steeringpump /crank |
looking for preferably an 8 rib serpentine pulley of aprox 6,5inch 167mm a 6 rib pulley of simular diameter is allso better as no pulley at all no cast iron but stamped steel or aluminum, as i have to weld on it... apparently this diameter was stock on at least bbc steeringpumps but there are prop. plenty other applications that these were used , so please check in your garage for that old engine/ steeringpump ? any help welcome guys !!! thanks, Jeejee |
| Author: | jinstall [ Sun Mar 29, 2009 4:07 pm ] |
| Post subject: | Re: serpentine pulley 6 rib of pref. 8 rib steeringpump /crank |
You have to start sending me these things by email so I can look here. |
| Author: | jeejee [ Sun Mar 29, 2009 9:42 pm ] |
plans chance so quickly, that i now don't need that diameter anymore, still not sure what diameter i need as i have to do some calculations for the new setup it may be best to start with the moderate setup and attend some bitburg events before i change to the bigger blower setup + boost that might kill the engine, and then i have nothing
| Author: | hotrodredneck [ Thu Apr 02, 2009 4:52 am ] |
I have a spare Stang power steering pump and pulley |
