It is currently Mon Aug 24, 2026 12:12 pm
 Post subject: Somebody lost his job.......
PostPosted: Mon Nov 06, 2006 11:28 pm
Simple tirechange gone wrong......
PostPosted: Tue Nov 07, 2006 6:19 am
Whoops!
PostPosted: Tue Nov 07, 2006 11:43 am
:shock:
That reminds me of my car on a lift at Kapaun Auto Skills. They had some strange lifts where you had to pull a lever AND press a button to lower the lift IIRC. If you only pulled the lever, only one side came down... :?
PostPosted: Tue Nov 07, 2006 11:47 am
OUCH!!! Dangerous ... but then, sometimes you only need one side up :lol:
PostPosted: Tue Nov 07, 2006 12:03 pm
Outch!
To me something like that happened the other way round... the camaro of a friend got stuck on the lift, almost on the highest position, 2 meters up in the air. A little piece of wire got somehow stuck in the thread rod of the lift :oops:
Somehow he didn´t want to hear all the jokes about that we could disassemble his car entirely and build it back up on the ground ;)
So, we spent the entire evening with moving the lift manually with a huge wrench till it spun free again...
PostPosted: Wed Nov 08, 2006 7:29 pm
Sembach Auto Skills...
you only got the lift down after you had it move up a little first...
Problem: somebody did not watch a vehicle with Soft Top more than touching the sharp corners of the overhead mounted heaters already.
PostPosted: Thu Nov 09, 2006 7:43 am
I used to work at sembach I wouldn’t recommend anyone going there unless you have to.
PostPosted: Thu Nov 09, 2006 3:29 pm
I would not want to be that guy. :lol:
