It is currently Sun Oct 04, 2026 3:06 am
 Post subject: Need Help with the vette/ Lancer033?
PostPosted: Fri Jul 07, 2006 4:57 pm
Well i have the service abs/ service traction lights coming on.Keith can you help me? i suck at electrical crap. The code i am getting is C1225H. It goes away when i restart the car, but soon as i hit a bump in the road it goes off again. I heard you can fix/ clean the connectors for the EBCM. I would appreciaye any help you could give me.
Harley
PostPosted: Fri Jul 07, 2006 4:59 pm
It's an 99 C5 BTW. My numbers are 016096524840 or 06155605796.
PostPosted: Fri Jul 07, 2006 5:47 pm
I'm all over this one, Did all of this myself over the winter. If you take it to a dealer get ready to be raked over the coals. Good news is it's easy to fix if you put in the time to trouble shoot it.
Start here
http://www.klh-racing.com/AH_TC_ABS_Info.htm
One thing to add that's I didn't put on this page is to check the brake fluid level. probably not that lucky, but it's worth a look.
Check on [url]forums.corvetteforum.com[/url] in both the C5 Tech and C5 General sections, there's a ton of info.
C1225 RF Excessive Wheel Speed Variation
try unplugging the RF wheel speed sensorr and cleaning the connecttions. Pay special attention to the female ends.
I'll be back sunday night if you need any more help
Lancer033
Keith
PostPosted: Sat Jul 08, 2006 8:56 pm
I tried cleaning the contacts on the sensors and got a c1233 code. pulled them apart again now the abs/ traction lights go off at 43mph and it's still throwing the c1225 code. i fuggin hate this car right now, but the again i love her. :roll:
PostPosted: Sun Jul 09, 2006 6:28 pm
C1233 RF Wheel Speed Circuit Open or Shorted
if should throw that code when it's disconnected. Make sure you've got it hooked up good. It's possible that it's the jumper harness. You can try disconnecting the jumper harness and swapping the right side for the left side. If the code then shows a problem with the left side, you'll just need to replace the jumper harness. If not, you'll need new wheel bearing/hub assembly. Order the Timken brand from Auto Zone. They are exactly the same as OEM, but ~$150 vs. ~$300 at the dealer.
directions for replacing them can be found here.
http://www.jakelatham.com/C5/misc/
Someone else will need to back me up on this, but I have been told to always replace bearings in axel sets, so You'll need to do both front bearings. It's a pretty simple job. The hardest part is seperating the lower ball joint, but a hammer will take care of that.
PostPosted: Wed Jul 12, 2006 5:24 pm
i am getting the 1232 code now. Which side is this? the driver or the passenger. I'm so frustrated with this car right now.
PostPosted: Wed Jul 12, 2006 7:29 pm
C1232 LF Wheel Speed Circuit Open or Shorted
Assuming you switched the 2 jumper harness, i'll bet that jumper harness is the problem. Check the connecters again, make sure nothing is bent, dirty or corroded or anything else that would keep the electrons flowing, if so clean it or bend it back, if all looks good, replace the jumper harness.
PostPosted: Thu Jul 13, 2006 1:04 pm
i am still getting a 1225 and 1232 code any ideas?
