It is currently Sun Oct 25, 2026 4:55 pm
 Post subject: disco lights
PostPosted: Sat Jan 05, 2008 2:02 am
OK here goes......
in past week or so I have noticed that ALL of my lighting *in my bird* surge.....its like some one is taking the reostat switch and running it up and down real fast but it also affects my exterior lighting as well......
What gives.....could this be a sign of a failing alternator? It was sugested that my Batt had corrosion but its a new batt and there side post not top. My volts tay steady WELL above 13volts, at least by my gauge reading.
:? :? :? :dunno:
 Post subject: Re: disco lights
PostPosted: Sat Jan 05, 2008 6:39 am
Just because you don't have posts doesnt mean you do not have corrosion. I would clean the entire connection including the wire terminal side and see if that helps. Also, check the terminal itself to see if there is a lot of corrosion it is possible for it to go deeper into the wire itself.
PostPosted: Sat Jan 05, 2008 9:21 am
Garry hook it up to a digital multimeter when it happens again
