It is currently Mon Sep 21, 2026 10:52 pm
 Post subject: Air Box
PostPosted: Fri Jun 01, 2001 7:51 pm
Just incase anyone wants to know about the sock airbox on the Z28. If you have a Dremel with the cutting disk you can cut out the whole front of the Air Box and remove the plastic piece that connects to the side of the car. By doing this you alow more air into the system. It makes a noticable difference to throttle responce. If anyone want's to do this and are unsure you can ask and I will explain.
PostPosted: Sat Jun 02, 2001 1:20 am
That sounds like the G2 airbox. It is better at bringing in the air, but go one further, throw that piece of crap plastic inlet tube away, and get some 5" (I used the orange colared one, when I did it) hose. This stuff is a fabric with wire coil construction. That will remove the real obstruction of the stock system, the inlet tube.
the above, along with removing the screen in the maf and relocating the IAT do more than people give credit for. IMHO
 Post subject: thought of it
PostPosted: Thu Jun 07, 2001 7:48 pm
What I was trying to do is find a way to run 4inch pvc piping from the air box to the maf. That should be ultimate air flow.
 Post subject: Whoa
PostPosted: Thu Jun 07, 2001 8:30 pm
Ryan you made member status.
Congrats
 Post subject: Hey thanks
PostPosted: Thu Jun 07, 2001 10:25 pm
You sound supprised. Long night's at Divarty EAC will speed up progress just a little. I figure once I hit two hundred I'll slow down. I want to see what happens when you hit a 2 hundred so hurry up and make your last post. your almost there.
