It is currently Wed Sep 16, 2026 12:06 am
 Post subject: IAC?
PostPosted: Wed Feb 13, 2002 3:05 pm
Cleaning all my loose parts for the time being just wondering if it's safe to clean the IAC w/ carb cleaner?
Probably wind up buying a new MAP sensor and IAC since those are the only things left used from the new engine.
PostPosted: Thu Feb 14, 2002 12:22 am
Sorry John, I cant remember what I read about cleaning it, but the carb cleaner sounds about right.
Besides, its not a really pricey piece, just replace. If only so you can be completely reborn.
PostPosted: Thu Feb 14, 2002 12:42 pm
Can't think what an IAC is but I read you shouldn't clean the wires inside the MAF with anything like that. I only posted just in case it was anything to do with that. If not, ignore this.
PostPosted: Thu Mar 14, 2002 6:40 pm
go get some Berrymans spray from Autopride on Vogelweigh.
Carb cleaner does not cut the carbon buildup nearly as well. When I clean my IAC I soak it in Berrymans for a few hours and then blow out w/ air. Works really well. Dries super fast too. I also use it to clean my intake tract from time to time using a fogger setup we have at the shop to spray it into the TB. I love that stuff.
SVT Slobra
