 Post subject: Spins with the slicks!
PostPosted: Thu Apr 10, 2003 6:19 am
It still freakin spins!
I was kickin total ass on the tree at seally last saturday, cut a .502 first round, and a .503 2nd round, then I cut a .580 and ran .12 off cuase it spun (2.05 60'!) I cant beleive im having traction issues with these HUGE ass slicks, (Which I got to try out on the street, (RAINING!) for two days and you cant tell they are back there.
I just got a set of V6 Springs for my camaro, and drilled holes in the bottoms
of each front strut.
What should I do to the rear suspension of my car to give a good hook?
Should it be soft, hard, or middle of the road, When do I need an Airbag?
Or will the V6 front springs and drilled front struts be enough to get the
car to hook?
13.022 @ 105.14
1.869 60'
PostPosted: Thu Apr 10, 2003 6:50 am
QA1 shocks set at 1 up front and 4-5 out back what type of slick is it? a torque bar would help also.
PostPosted: Thu Apr 10, 2003 8:02 pm
It is a Mickey Thompson ET Drag... Race only full all out drag slicks..
do you mean I should get an adjustable torque arm? Im a welder I can make on of those pretty easy.. how much would it help? or do I just need a more ridgid torque arm... What kind of springs should I have out back?
13.022 @ 105.14
1.869 60'
PostPosted: Thu Apr 10, 2003 9:02 pm
Are they tubed and screwed? That should help greatly.
Mav
PostPosted: Fri Apr 11, 2003 6:13 am
no, not screwed or tubed, but I never checked to see if the rims were spinning in the tire... would they still squeel if that was happenning?
13.022 @ 105.14
1.869 60'
PostPosted: Fri Apr 11, 2003 6:23 am
stiffer is what you want on the TQ arm and about 2 degrees neg for the pinion angle. Sounds like a weight tranfer problem did you remove the sway bar? I do not think your wheels are spinning on rim what is your air pressure?
PostPosted: Sat Apr 12, 2003 2:37 am
yeah, I pulled the front sway bar off a LONG time ago, and I run 10psi at one track, and 15 at houston raceway park where u can hook if u coat the tires with vaseline..
I JUST put on (like an hour ago) V6 springs and I drilled out my struts...HOLY "He said POOP" the nose feels like something is exploding under now every time I take off... Its got GOOD weight transfer now I would hope ;-)
Should I put those V6 springs in the back? or are the stiffer V8 springs better, or is there a diff betweem the two on the rear, one thing is for sure the car looks AWSOME with about a 1 1/2" Drop in the front ;-)
13.022 @ 105.14
1.869 60'
PostPosted: Mon Apr 14, 2003 1:50 pm
Vaseline? Haven't heard about that one.
PostPosted: Mon Apr 14, 2003 8:01 pm
(sarcasm) Houston hooks good
13.022 @ 105.14
1.869 60'
PostPosted: Fri Apr 18, 2003 4:13 pm
Ok I put V6 Springs on all four.... Lowered the car at least 1" all around looks good I think ;-) (picture in signature is with car lowered)
13.022 @ 105.14
1.869 60'
