It is currently Mon Sep 21, 2026 12:45 pm
 Post subject: Tranny swap!
PostPosted: Tue Mar 01, 2005 4:17 pm
Hallo evrybody!
I´m new to this board and am proud owner of 95 Trans Am V8 LT1.
My problem is, i have broken tranny 4L60E and fixing it in Spain is very expensive.
Now a friend of mine has busted his truck, it is a 4.3 V6 Astrovan which he put neatly against wall. (Winter is cruel).
However his tranny is still operable and now he is parting Van out.
my question: Will this fit into my TransAm?
Please please help me!
Regards,
Mephy :D
PostPosted: Tue Mar 01, 2005 5:48 pm
I believe there is a difference in lengths between the two also I believe the bolt pattern is different, but not sure.
PostPosted: Wed Mar 02, 2005 12:25 am
what year is the van. I am pretty sure the 4.3 has the same bolt pattern as an old small block and I also thought the lt1 did to. If the van has a 700r4 it would probably work but I think you would have to modify things in your computer or get a computer from a 6 speed car.
most of this is guessing because I don't have first hand info. but if you search some of the bigger boards from the states you should be able to find the answere.
PostPosted: Wed Mar 02, 2005 11:58 am
It is from a 96 Astrovan and is a 4L60E.
Rgds,
Mephi :P
PostPosted: Wed Mar 02, 2005 4:01 pm
I would think they is the same but not for sure
PostPosted: Wed Mar 02, 2005 4:39 pm
couldn't find anything on the electronics but they should be the same physical diminsions. I would probably count the output shaft splines just to be safe though.
chad
PostPosted: Wed Mar 02, 2005 5:59 pm
The V6 and the V8 have the same bolt pattern. The van will have a different Servo in it but it will only cause it to shift smoother. Make sure you add a tranny cooler and don't run it too hard on the top end. The 4L60e generates alot of heat when run at high rpm in overdrive. I would check the wiring harness connector on the Astro's tranny just to make sure. It should fit. I think you will need to transfer your tailhousing off of yours because of the torque arm hookup. It is only 4 bolts so it is easy. Good luck.
PostPosted: Thu Mar 03, 2005 11:50 am
Whew.
I take it as:
Yes it will fit with some playing around :=?
Anyway, i´ll buy it and hopefully if i run into major trouble i can ak for more help?
One more question: Will the torque convertor fit too or do i us my old one???
Rgds,
Meph
PostPosted: Thu Mar 03, 2005 7:03 pm
O.K. here is the deal. I I just checked some web sites and it looks like the v-6 4L60e has a smaller bell housing and will not fit a V-8. Roy was right. Here is the webstie to a company that I bought my 4L60e for my 95 LT1 Camaro from. They should be able to answer any question you have. Sorry about the bad information.
http://www.transmissioncenter.net
PostPosted: Thu Mar 03, 2005 7:27 pm
is the bolt pattern diff or the size of the bell housing? I know when I was looking into doing a old s10 blazer I wanted one with a 4.3 because the 700r4's would bolt up to a small block.
PostPosted: Fri Mar 04, 2005 1:37 pm
The bellhousing is smaller.
