It is currently Sat Oct 17, 2026 8:06 pm
 Post subject: 1995 Z28 problems
PostPosted: Fri Aug 07, 2009 4:58 pm
x
 Post subject: Re: 1995 Z28 problems
PostPosted: Fri Aug 07, 2009 8:22 pm
You are the one that got it! From the junkyard right? Good find. A buddy just told me about it.
Well, there are a lot of things that could be wrong. Are you sure the pressure is at 58 and remains? I would start with a fuel filter first.
From there I would start looking at the opti.
PostPosted: Fri Aug 07, 2009 9:17 pm
Oh man, an opti issue?
01 TA-M6-Blue
PostPosted: Fri Aug 07, 2009 9:22 pm
x
PostPosted: Mon Aug 10, 2009 10:48 am
Dude, you got a Camaro, sweet. I know that one of my friends before had a C5 and had the same problem and it ended up being a cracked intake. Anyway, dont forget Im not too far away. Call me after 5.
PostPosted: Wed Oct 14, 2009 7:50 pm
x
PostPosted: Wed Oct 14, 2009 8:59 pm
Thanks for the update. That is a fun change. Good luck.
