It is currently Sat Oct 24, 2026 5:25 am
 Post subject: Paging Randy......
PostPosted: Thu Aug 09, 2001 12:03 pm
I hear that you have a 94 parts car. Would youu have the lead and plug that goes into the water temp. sender? When I put in my headers, I ripped mine out at the plug and I cannot fix it, and therefore, my water temp gauge will not work. I just need the plug and a few inches of wire with it. Can you let me know?
Thanx,
PostPosted: Thu Aug 09, 2001 6:24 pm
I would help you out, but Im selling the motor and wiring harness as a complete unit. Sorry bud.
