It is currently Sun Sep 13, 2026 10:50 pm
 Post subject: Update on the 2nd gen....
PostPosted: Sat Apr 17, 2010 5:48 pm
Well, got everything attached and hooked up aand did an oil change. Fired it up and after adjusting the timing a bit, found out #6 is slapping so im kinda pissed... but what can ya do.... interior is looking better every time i work on it.... got my wheels in finally... old chevelle rally wheels with the SS centercaps. 15x8 with a 4 in backspacing. Im thinking 275/ 60 r15 in the rear and 235/ 60 r15 out front. the parking brake cable is coming, and after that its just the tailpipes and getting the dash to light up and i'll run it through inspection.
 Post subject: Re: Update on the 2nd gen....
PostPosted: Sat Apr 17, 2010 5:57 pm
You may have trouble passing inspection with different size tires .
PostPosted: Sat Apr 17, 2010 10:12 pm
German regulations allow it, if it's in the car documents ...
