It is currently Wed Sep 23, 2026 1:08 pm
 Post subject: Firebird 3.4L engine problem
PostPosted: Fri Jun 24, 2005 3:23 pm
Hi,
I write for my friend's 1993 firebird V6 3.4L who has a problem with his car.
When he start engine runs (sometime with difficult) but when he wants to accelerate, engine stop.
Personaly I think it could be his ECM (fuel problem) or fuel filter. What do you think?
Where is the fuel filter on V6 engine please?
Thanks
ALBORZ
1991 Z28 V8 5.0L TPI TH700R4
PostPosted: Fri Jun 24, 2005 5:50 pm
Judging from your description it could be many things but assuming it's a fuel problem i would simply have the Fuel pressure measured.
Once the engine starts it should give you a value which (exact value is not really that important as long as the engine runs), then rev up the engine and if the value then dramaticly drops it's a fuelpump/filter problem !
He's not gonna be too happy if that pump fails since it will require him to lower the entire rear axle to lower the tank and acces from the top :(
Or he could cut a square 'hole' in the rear trunk area to acces the tank directly (some people prefer to do that as it saves quite a bit of time.
But let's not jump to conclusions just yet, i would first have him go to for instance Opel Haus and have the fuel pressure checked, especially under load.
Users browsing this forum: No registered users and 29 guests
