It is currently Fri Sep 18, 2026 5:59 pm
 Post subject: Gears or Cam?????
PostPosted: Fri Oct 26, 2001 7:30 am
Here's a question for everyone.
I am looking into getting better performance out of my ride (like no one else is)... but I am either thiking of getting a new cam and hedders or hedders and a new rear end (either a 3.73 or a 3.90 I don't want to go to excessive). Now my dilema comes becuse I want the hedders and can't decide which of the other I want. I have just enough $$ to get a really good rear end... or just enough $$ to get an ok cam and ok springs... but when I go to do my cam I want to also put in roller rockers, new lifters as well.
I'm just trying to get a fell for what some other people would do if in the same shoes as me.... Any suggestions would be appreciated!
Later!
PostPosted: Fri Oct 26, 2001 8:05 am
Being the newbie, I can't say what the cams will give you, but I personally would go with the gears. They are a big gain in performance. And they do not effect the drivability or emissions, if you care about that. Gears are going to be one of my first mods. Peace
PostPosted: Fri Oct 26, 2001 8:31 am
Not knowing your budget, I don't know what to tell you. For me, the gears would be cheaper, since a decent cam setup with roller rockers for me would cost nearly $1500. I guess it would be cheaper for you. I would prefer the cam setup myself.
PostPosted: Fri Oct 26, 2001 8:38 am
Well JR, I personally would do both. You can pick up a used set of gears in 3.42 for about $75. I would try that size as alot of autos are running them, when they get power.
I would look on the boards and ebay for a cam and springs. There are always people selling their cams. If you need help and want me to keep an eye out let me know. Tell me your budget and I will send you what I find.
Get the best of both worlds.....
PostPosted: Fri Oct 26, 2001 8:44 am
Same here, I am alway looking to see what's out there.
PostPosted: Fri Oct 26, 2001 9:14 am
Trust me...this guy can find you anything!!!;)
I agree that both would be better, but if you really can't afford it, just go with the gears. Heard it is a major difference with the auto!!;)
PostPosted: Fri Oct 26, 2001 9:53 am
JR you know your going to change out everything any way so I would buy the best mods you can one at a time. Instead of trying to buy alot of middle range mod's you will end up changing out later anyway. Just my 02 cents. I have been working on my car for 4 year's and still have a long way to go. JAZ
PostPosted: Fri Oct 26, 2001 9:59 am
Well as most mods bought used retain their value and if you do the work yourself, midrange mods can be had now as a loan. Run the extra power now and upgrade later. You will make your money back if you buy used. I bought the MAC headers as they were $600 shipped. I know I can sell them for close to $500. I will upgrade to longtubes later, but I have had them for almost 8months. That is 8 months of extra power and performance... just my $.02
PostPosted: Fri Oct 26, 2001 11:13 am
I dont knbow what your budget is but here's what I would do and I speak from exsperience....
You can get the hotcam kit comes with cam, springs, retainers, roller rockers for about $450. Gears will run you in the neighborhood of $180( I reccomend Motives in the flavor of 3.73) And a good custom tune. Add some shortie headers for about $350-ish. If you can only afford 2 of these mods, go for headers and gears, you will need them to put any decent cam in.
PostPosted: Fri Oct 26, 2001 11:27 am
Go gears, no higher than 3.73's. Think about the headers next.
Jeffs right that a cam on its own, is not going to do much for you until you have the intake (heads) and exhaust (headers/ypipe/) to support it, plus the PCM change so the car knows it has it.
Me personally, 1. Gears 2. Headers 3. Torque convertor
BTW v8zspeed
1500 for a cam and rocker setup? What is it made out of? Diamonds and platinum?
PostPosted: Fri Oct 26, 2001 12:04 pm
Wow that was alot of replys.....
Well I have thought it over and I'm going to go with gears and hedders first... then I'll get the cam in a few months.... My budget is about $1200 and that's got to get the hedders, gears, (and the new pinion bearing I need...) and I also want to get stripes painted on the car... but I'm getting the estimate tonight so I'll find out if that is do able as well.... but I want performance first than looks. Like I said thank you all for the suggestions!!! Keep them coming if you have any more! Later!
PostPosted: Fri Oct 26, 2001 12:06 pm
Forgot...
George if you could help me find a set of hedders (package w/ y pipe, and install kit.. bolts.. ect.) and a set of 3.73 gears...(I'm willing to sacrafice some top end for more pull at the bottom since I leave Germany soon.. where else will I get up to 120 leagely?) I would greatly appreciate it! Thanks!
PostPosted: Fri Oct 26, 2001 1:11 pm
If you get shorties, they bolt up to the factory exhaust. At least the BBK's do. You want mine? I want some long tube's.
PostPosted: Fri Oct 26, 2001 1:28 pm
I was kind of looking at the edelbrocks because they come with everything......
Whats wrong with yours???
How much do you want for them????
Will I need a new Y pipe?
Where can I get all of the stuff to bolt them up?
Do they sound good?
PostPosted: Fri Oct 26, 2001 2:38 pm
You can have everything you need off my exhaust to make it work with yours. There is nothing wrong with them other than they are chrome. I figure with the engine out, its the easiest way to put those long tubes on...
PostPosted: Fri Oct 26, 2001 2:41 pm
How much do you want for them?????? Do you think I can still use the gasketts or where I can get them!
PostPosted: Fri Oct 26, 2001 2:48 pm
Damn, your that serious? Cool! I'd say um....$100 for them headers. You would deffinitely want to get some new gaskets and locking bolts. As for where: Summit, LG Motorsports, Jegs, ThunderRacing...
PostPosted: Fri Oct 26, 2001 2:50 pm
Let me talk to the wife and let me look at them again... but I 98% pos I'll take them!!!!!!!!!!!
PostPosted: Fri Oct 26, 2001 4:21 pm
I'll tell you that for an A4 car, the best mod for the money is a torque converter. It will make a HUGE difference. I put a 3K stall speed Vigilante on my 95 and it was amazing!!! I didn't get a chance to run my car at the track after the TC, but most people drop their 1/4 times by .5 -.7 depending on the converter!!!
The TC will give you the most gain of any mod with the exception of NOS and Forced Induction.
Mods I'd do in this order:
1. Torque Converter
2. Gears
3. Headers
4. Cam
-- Jamey --
PostPosted: Fri Oct 26, 2001 4:41 pm
Yup, stripes do help the HP ... I should know, after all I beat Bruce on the 7th ... and that was all just the stripes ... 6 per side, times 10HP per stripe ... add it up ... got that tip from a Honda driver ... :)
NOT!
Anyway, you may want to try them as stickers - I got mine as decals, and they worked great ... they will hold quite a couple years when treated decently and done right, plus you can get rid of them easily without a new paint job ... if you want to, I can hook you up with the guy that did mine ...
