It is currently Fri Oct 16, 2026 9:14 pm
 Post subject: Searching for BCM Module OR Power-doorlock cables
PostPosted: Sat Nov 10, 2001 1:38 pm
Hi,..
i wrote in another Thread, but there came no answer.
I'm searching for the location of the Body Control Module
in a 99' Camaro Z28. I've opened the plastic under the steering wheel and can see hundreds of cables. I need only 4 or 5 cables...
but the right ones ;-) I won't teardown the completely electrical System of the car.
under the Steering wheel is a little bit left a big Module.
it could be this Module, Can i screw it out without Problems?? In
the Midle is a red Screw. From the front i don't came to the right cables if it is that Module. (at first i disconnect the ground from the Battery, before i test any cables...
I nobody know where this Module is, I'm searching only for a pair cables. 2 cables to lock and unlock the completely door System,
i cable to open the electrical hatch door (?) and ground and +12V..;-) the last is not the Problem, but it was good if i take the
same Electrical-Line like the BCM Module has.
Thank you for answers... I Hope anyone know where the Module is... has nobody a Service-Manual for that car???
Please take a look on it.. i have no one.
only the dammed Haynes Manual...;-(
AndreasH
99'Camaro Z28
PostPosted: Sat Nov 10, 2001 2:08 pm
I hope this helps
Alarm Install
PostPosted: Sat Nov 10, 2001 3:39 pm
Hi,..
thank you for the Info.. it's very great! ;-)
I've teardowned my half car...The power Lock funktioned by Hand,
and the info that i must wake up the BCM-Module, is new too,
but i build it in, it's no Problem.
If i'm ready it comes on my HP...
AndreasH
Users browsing this forum: No registered users and 20 guests
