It is currently Tue May 05, 2026 7:16 pm
 Post subject: Dynamat
PostPosted: Tue Oct 23, 2001 5:16 pm
Hey Jaz,
Do you guys sell dynamat, or know where I can get a good deal on some. I have heard it helps cut down on some of the exhaust resonance and makes the stereo sound better, so I am thinking about putting some in my car.
PostPosted: Tue Oct 23, 2001 5:52 pm
It also helps keep outside noise outside where it belongs!! ;)
PostPosted: Tue Oct 23, 2001 6:08 pm
That's what I am hoping.
PostPosted: Tue Oct 23, 2001 6:10 pm
Let me know.. It will be some good stuff to keep the loudmouth outside....
You can also pull all of you door panels and carpet and spray the black undercoating. It deadens the sound really well. I did it to my 4runner and it worked great.. It is a little messy until dry..
PostPosted: Tue Oct 23, 2001 6:30 pm
also adds some much "needed" weight to the car.
Definatelly helps cut Db's down, but then again. If a person chooses to put on a loud exhaust, well......?
Summit caries it BTW, and Summit = free shipping.
PostPosted: Tue Oct 23, 2001 6:31 pm
That was my other plan, but like you say you have to wait till it's dry to put back together and I don't have a garage. Basement full of tools, but no garage.
PostPosted: Tue Oct 23, 2001 7:01 pm
Pull the interior carpet and door panels. Put them in the basement. Spray the whole car. If it is not dry and you need to drive just put in your seat....
PostPosted: Tue Oct 23, 2001 7:18 pm
I don't know about discount places but I know for a fact that crutchfield has it. http://www.crutchfield.com ;)
PostPosted: Wed Oct 24, 2001 5:49 am
I think summit was cheaper than crutchfield... but crutchfield has slightly faster and cheaper shipping. Just some FYI.
PostPosted: Wed Oct 24, 2001 6:31 am
I have acumat made by EFX it is lighter and much easier to work with than dynomat. Trust me I have done enough trunk's to know. I also have spray on sound dampining that work's great but it cost a little more it's alot more work for me. The regular acumat is two layers together one foam and one rubber and it is super light so if your worried about weight I would go with that. JAZ
PostPosted: Wed Oct 24, 2001 7:32 am
Jaz, what's the pricing on that stuff, and do you have to put it in, or can we just buy it and do it ourselves???
PostPosted: Wed Oct 24, 2001 7:37 am
What Jack said.
PostPosted: Wed Oct 24, 2001 7:41 am
George the loudmouth is a resonance frequency problem. You either have to cancel the frequency or change it. I find that no.3 steel wool stuff up the pipe really worrks as a temporary fix . About 4 biscuits of the stuff work for me.
PostPosted: Wed Oct 24, 2001 7:54 am
Does it not burn Roy??? :-dunno:
PostPosted: Wed Oct 24, 2001 8:46 am
I CAN GET IT IF YOU WANT TO DO IT YOURSELF. IF YOU STILL WANT A INSTALL I CAN PUT IT IN WHEN I DO THE INSTALL. IT WORKS GREAT. I WILL CHECK THE PRICE LIST AT WORK TONIGHT AND GET BACK WITH YOU. JAZ
PostPosted: Wed Oct 24, 2001 9:30 am
Danke!!
PostPosted: Fri Oct 26, 2001 1:22 pm
OK the normal price is 179 for a box of 8-24"x27" sheets.
Rob said he will give it to us for 150 a box. JAZ
PostPosted: Fri Oct 26, 2001 1:38 pm
Sounds good to me. I will have to get back with you after payday. i am in.
PostPosted: Sat Jul 06, 2002 12:34 pm
Ok, I used and I am using Brown bread, it's cheaper and works better, and without the asfalt smell.
bquiet.com
mail me I've you like to see results of if you have questions
gr Peter
www.KandyCamaro.com
PostPosted: Mon Jul 08, 2002 1:47 am
I am a authorized dealer for acumat it just depends what you want that's what I can get cheaper than any others. If you have ever heard my car you know it work's!!!!!!!
