It is currently Sat May 02, 2026 5:24 pm
 Post subject: Donkeykiller is sick****Please help him!!!!
PostPosted: Sun Aug 25, 2002 6:40 pm
Okay, hears the situation. Ever since I put my S/C on, my SES light has been on putting me in limp mode. I thought my engine was pinging so I bypassed my knock sensor to see if it would solve the performance problem. No luck but I seemed to have felt a little pick up in performance. I returned my knock sensor the way it was and I'm back where I started.
Now, after doing nothing at all to the car, my engine feel like it is running on 4 or 5 cylinders because it is missing so bad. It idles normal but when I press the gas it misses bad. Since this problem, if I disconnect and reconnect the battery, this problem will go away for about three minuites or so and then it will start acting up again. I can barley spin the tires in first gear. I checked my plugs and wires and nothing was fouled out and the wires were still in good shape. From this point on, I am clueless on what to try next. All I can think of is that I still have my stock knock module and I have not had my cpu reprogramed ever.
I'm thinking the SES light could be fixed by reprogramming the cpu and because I waaited so long to do this that my computer is going haywire.
Please help!!!!!
PostPosted: Sun Aug 25, 2002 8:21 pm
Hmmmm. What year is your car? Check to make sure you have no intake leaks after the MAF, that will cause it to run like you state.Maybe you need a new MAP sensor with that huffer?
Now where are you located again? I have a reprogramed PCM by Ed Wright for a Hot Cam, shorties, 4.10's 52mm TB ect. What cam do you have? We can try throwing my PCM in yours and seeing what will happen. I also have a LT4 KM in it also.
 Post subject: Jeff
PostPosted: Sun Aug 25, 2002 9:50 pm
The MAP sensor, I never thought of that. Its just that everyone I speak to with a Powerdyne never mentions that they changed out any sensors. But all of them did have reprogrammed CPU's. This is starting to make sense that I should consider getting this done. How can I check to see if it is the MAP sensor?
I am in Bitburg so it would be tough to get together and try swapping out CPU's but if you are ever in the area give me a buzz cause I am all for any kind of help. My car is resting in the parking spot and I dont think I should drive it much with it acting up.
PostPosted: Sun Aug 25, 2002 9:51 pm
Oh yeah, my Z is a '94.
PostPosted: Mon Aug 26, 2002 11:11 am
Have you done a compression test on it since it has been acting up?
PostPosted: Tue Aug 27, 2002 8:29 pm
I hope you get it squared away soon I plan to race you with some gears.
 Post subject: sven it's sven. 93 LT-1 Auto
PostPosted: Thu Aug 29, 2002 12:12 am
last resort, take it to a opel/GM dealer
1999 GM LS-1 T/A
2005 Suzuki GSX-R 1000
PostPosted: Fri Aug 30, 2002 3:22 pm
Howie what are you doing over there man! What ever you do don't take it to the opel dealer over there they suck!!!!!!! Sine I have to go to GM (to get an estimate to shipping damage) I'll ask them over there what to watch out for. Good luck!
PostPosted: Sun Sep 01, 2002 10:16 am
haven't done a compression check yet. Never thought to do that. I just sent off the PCM to get it programmed in the states. Hopefully it will be back in time for the races.
I dont plan on going to the OPel dealership cause JR's right, THEY SUCK!!. Hopefully this reprogramming will getr rid of the Engine light.
I did in fact find the number seven plug wire burnt almost in half. This was after I sent off the PCM so I didn;t get to start it up to see if it stops missing. I hope so.
 Post subject: spark plugs wires
PostPosted: Wed Oct 02, 2002 6:16 am
Don't know how much this will help, but I had a similar prob with mine. I had 2 wires on the passenger side burn out on the headers and the car would shudder violently especially in O/D. I eventually had to run the wires over the valve cover. I have Hypertech power tuning, I think that it screwed up my computer. Through all the probs I never once had a "service eng soon" light.
