It is currently Sun Jul 19, 2026 4:30 am
 Post subject: Winter buildup
PostPosted: Sun Oct 13, 2002 8:13 pm
Kinda bittersweet. I sold my notchback today (still hurts), but now I can have my block machined and the rotating assembly put in it.
Nothing special, just new pistons/rings, and crank/cam bearings. Probably more aggressive cam/springs, and a dyno tune.
I figure that should allow me to drive the 1hour to the track, run some mid 11's and drive home for some Saturday night cruizing.
Now I just have to stick to my plan.
PostPosted: Sun Oct 13, 2002 8:22 pm
Sounds kewl so you going 383 or 355? I am hearing some good stuff about the CC305 for the LT1.
PostPosted: Sun Oct 13, 2002 8:54 pm
That is the million dollar question. Right now I'm thinking about just getting pistions and reusing everything else to keep costs down. So it looks like a 355. The CC305 does seem to be the most popular cam, but since I have the HOTCAM there really isnt enough(if any) differance to justify the swap.
I'm thinking a custom N2O grind. This is gonna be a weekend/drag car. So It will probably be a relatively aggressive cam.
Still doing my homework, and I'm not committing to a path until about November, so plenty of time to play around with combinations
PostPosted: Sun Oct 13, 2002 8:58 pm
Sweet. Can I ask what you got for it? Or maybe I should ask whether you got more than what you paid for it.
PostPosted: Sun Oct 13, 2002 9:02 pm
Rob that Venom kit rocks. What kind do you have?
PostPosted: Sun Oct 13, 2002 9:10 pm
I have a choice. TNT F1 and a NX wet kit.
I'll probably stick with the TNT, only problem is I have to do some surgery to the thermostat housing, because with the 52mm Tbody and the TNT plate there is some interferance. Really well thought out kit though.
PostPosted: Sun Oct 13, 2002 9:12 pm
Are they wet?
I have heard good thing about TNT kits. NX seems to be pretty popular also.
PostPosted: Mon Oct 14, 2002 5:08 am
Both kits are wet, but the problem with the NX is the nozzle placement. There really isnt a good way to secure it. I just keep seeing the nozzle come out and spray N20 and gasoline all over the FLP's. Not cool.
The TNT uses 2 nozzles (left and right) and its in a machined plate (very secure).
Here are the 2 systems
http://www.racenet.net/image/irs-nitrouspkg.jpg
http://www.thunderracing.com/images/lt1tntkit.jpg
plus I have heaters for both, and NX bottle opener. Only thing I use extra is the MSD window instead of the Mallory. That and the MSD DIS 6 hooked to the N20 solonoid so when its active it retards 3degrees of timing
PostPosted: Mon Oct 14, 2002 7:58 am
Go with TNT. It looks better and like more of a quality kit.
PostPosted: Mon Oct 14, 2002 7:16 pm
How quick are you trying to go?
PostPosted: Mon Oct 14, 2002 7:58 pm
Whatever it'll do, then I'll go from there. :)
My philosophy has always been to use all of what you got, so instead of continuously throwing the checkbook at it, I'll maximize what it has.
I figure with a blueprinted 355, ported LT4 heads, decent cam and 100-150 shot I dont have any excuses if it wont run deep in the 11's with a sorted out suspension. The car may be capable of more, but the driver has to catch up to it.
PostPosted: Mon Oct 14, 2002 8:46 pm
I will share lessons learned. If I get rid of my mid track spin I shoud be good shoulda tried the other lane.
