It is currently Sun Jul 19, 2026 3:10 am
 Post subject: ABS problems and Cruise Control
PostPosted: Fri Oct 18, 2002 5:18 am
Like I said I bought my car running like a POS with 114,000 miles and I had to fix alot of stuff. 2 Things I haven't fixed were
A. The ABS light is always on and my brakes will lock up when I get down on em (meaning ABS dont work)
B. The cruise control wont work
The primary reason why I haven't fixed these yet is because I dont know how lol. I put the Snap On scanner in my LPT.. no wait thats a printer lol my umm damnit that port under the dashboard port! lol and it had a list of 99 ABS trouble codes they all said this LF LR RR RF Abs sensors short to ground or short to 12v and the codes were appearing repeatedly over and over.... Does any1 know why the computer would be recording this and why my ABS dont work from these clues....
Also my cruise control just dont do anything.. Is that a common thing to break on these cars. What are the most common reasons it would break.
13.022 @ 105.14
1.869 60'
PostPosted: Fri Oct 18, 2002 4:10 pm
Have you checked all fuses?
PostPosted: Sat Oct 19, 2002 1:51 pm
I know what the problem is, I had the same thing happen to me! More than likely your third eye level brake light (in the spoiler) has a failed bulb. For some reason there is nothing in the user manual about that. I think its GM's way of getting you into the dealership
PostPosted: Sat Oct 19, 2002 2:08 pm
Hey Florida, where are you from exactly? I am originally from Tallahassee.
PostPosted: Sat Oct 19, 2002 6:41 pm
Ft. Liquordale,FL
PostPosted: Sat Oct 19, 2002 10:11 pm
 ICQ  YIM  Profile
Jack, you are from the FLA? I thought that Mike was the only other one around, and now he is gone. I thought Tally was part of Alabama anyway.
RT1 - Image
PostPosted: Sat Oct 19, 2002 10:39 pm
Alabama???? Screw you. It is actually only like 20 miles or so from Georgia..
PostPosted: Sun Oct 20, 2002 2:36 pm
 ICQ  YIM  Profile
Still seems like Banjo-land to me. ;)
RT1 - Image
PostPosted: Sun Oct 20, 2002 2:50 pm
LOL, ah cain just heeyer thaim banjos playin'..
PostPosted: Mon Oct 21, 2002 1:54 pm
Ft. Liquordale,FL
Hey my brother lives there....... you don't by cahnce work at a VW dealer??? I told one of his TA driving friends down there about this site.
PostPosted: Tue Oct 22, 2002 12:48 am
umm can you elaborate? on the third brake light thing?
Come to think of It I dont think I have ever seen that light up but what does that have to do with ABS? or Cruise control yeah which 1 are you talking about?
PostPosted: Tue Oct 22, 2002 1:30 am
Jr,
No i dont work there, i just found this board thru google.
badazzlt1USA,
I dont know why but, my abs light stayed on all the time and my cruise control did not work either. I looked thru the service manual and could not find anything on this. A while later i noticed my third eye level brake light (in the rear wing) was not working. I repaced the bulbs and to my amazement the abs lamp went out. Then I tried using my cruise control and it also worked. for some reason GM never documented this in there owners manual. The only thing i can see in common is they all have to do with the brakes, cruise control module monitors the brake lamps to see when to shut off, ABS monitors brake lamps to know when to engage. I am pretty sure if you replace your third eye level brake lamps both of your problems will go away.
Let me know if that works out for you!
c-ya
PostPosted: Tue Oct 22, 2002 2:09 am
wow dude totally bitchin! Ill try it right away and post results meanwhile I got some more probs.
PostPosted: Tue Oct 22, 2002 11:20 pm
wow 95whiteTAflorida I could just kiss.......that big titted chick in your picture lol.
I looked in my 3rd brake light and the 2 bulbs were BLACK I put two new 1's in and put the tailight together. WALLA!!!!
The ABS INOP Light is gone! I didnt get to test drive it to see if the cruise control works and I wasn't gonna fool with it will the car was on a trailer just in case lol.
But wednesday ill drive it to Houston Raceway park and on the way test the cruise control and ABS... Finally I wont have to guzzle so much gas......I hope
Man this has got to be the querest thing to ever happen to a car... If i took it to a garage.....(which I would never :) ) It woulda cost a fortune to fix that. Not $1.50
