It is currently Sun Sep 13, 2026 5:30 am
 Post subject: Torque Converter Clutch
PostPosted: Sat Nov 23, 2002 3:50 pm
Anyone who knows about old school dragracing knows real torque converters slip....which is good becuase it keeps the motor's RPMs high up in the powerband.
The LT1 has a Lockup converter......when you shift into 3rd the computer kicks on a solenoid that locks up the clutch eliminting slippage.
When my car hits 3rd gear it bogs badly.... If I turn the torque converter clutch off with LT1 edit to let the Torque converter slips will I get less bog and better ETs?
The converter is built to lock up in 3rd gear to save on gas btw...its not for performance
13.022 @ 105.14
1.869 60'
 Post subject: Re: Torque Converter Clutch
PostPosted: Mon Nov 25, 2002 4:41 am
Yes if your torque converter locks up in third gear then it will run better if it is turned off. You might consider making it lock off in fourth instead.
PostPosted: Mon Nov 25, 2002 5:32 pm
ok thanks very much hotrod ill do that
any idea how much it would pick me up :)
Its my own idea I never heard of anyone doing it b4
even though I know I can disable it with Lt1 edit
13.022 @ 105.14
1.869 60'
