Page 1 of 1
[ 12 posts ] |
zcam94
Post subject: Air Conditioner Problems Posted: Wed Dec 25, 2002 10:00 pm |
Joined: Sun Jun 24, 2001 1:32 am Posts: 324 Location: Giebelstadt, Germany
Its winter so now is the time to fix everything, I'm getting a real bad squeak from my belt. The belt was replaced about 150 miles ago. I've narrowed it down, when the heater is on the belt squeaks. It seems the AC pump is locked up or something. Anybody have any suggestions or quick fixes??? Is it possiable to bypass the pump without a lot of hassle?
Post subject: Posted: Thu Dec 26, 2002 10:09 am |
zcam94
Post subject: Posted: Thu Dec 26, 2002 11:42 am |
What do you mean by free wheeling? When the heater/ac if off there is no squeaking. Plus, I've ran the car about 15 miles today and it hasn't squeaked once with the heater on??? I don't know if the car just wants attention from me or it actually has a problem (and before you laugh, cars have hearts too!!!).
Post subject: Posted: Thu Dec 26, 2002 3:56 pm |
Well it definately is not locked up or it would of smoked that belt in two in a matter of minutes.
It more than likely is improper belt tension ...
a. belt is just a hair too long or
b. automatic tensioner is getting weak. or
c. grease or contaminate on the belt.
zcam94
Post subject: Posted: Thu Dec 26, 2002 6:27 pm |
I'll check those out. Thanks Roy.
zcam94
Post subject: Posted: Sun Dec 29, 2002 3:53 am |
The belt is the right size, and it looks prettly clean. The tensioner pulley seems ok too. With any of these things you listed, wouldn't cause the belt to squeak non stop?
Post subject: Posted: Sun Dec 29, 2002 11:11 am |
zcam94
Post subject: Posted: Sun Dec 29, 2002 5:18 pm |
Its the serpintine belt. I'm gonna disconnect the ac pump next.
zcam94
Post subject: Posted: Tue Dec 31, 2002 4:11 pm |
Roy, would make any differnce if I took out the ac relay? I couldn't really find a fuse for it.
Post subject: Posted: Tue Dec 31, 2002 6:13 pm |
IF your trying to kill power to the AC clutch , look for a wire connector comming from the the A/C and disconnect it.
I can't tell you anything about the A/C relay . I donot have a schematic handy to view.
zcam94
Post subject: Posted: Sun Jan 05, 2003 8:33 pm |
You're right Roy. I disconnected the ac clutch connector and no squeaking now. Thinking about dropping the whole ac unit all together. Might be a few pounds lighter.
_________________ Stock Throttle Body bored 52mm, Modified airbox, desreened MAF,2800 Vigilante Convertor, Vortex Aluminum elbow, Grant D-Shaped Steering Wheel, Hooker Cat-back. Parts wating: cold air induction w/K&N
Post subject: Posted: Sun Jan 05, 2003 9:25 pm |
The AC clutch is a easy repair job . The clutch usually runs around 100 dollars and usually can be replaced with out discharging the system. Good luck with ever way you choose. I always had the badluck of removing the AC and get assigneed to someplace like Campbell or bragg and the humidity kicks my asss.
Page 1 of 1
[ 12 posts ] |
Users browsing this forum: No registered users and 25 guests |
