It is currently Sat Sep 12, 2026 6:56 pm
 Post subject: Electrics - agghhh
PostPosted: Tue Jan 21, 2003 2:06 pm
Car alarm.
I've had a few false alarms on my car (96 z28), always in the wet and to date they have always cleared by locking/unlocking the doors (so turning the alarm on and off).
Today its having none of it. If I set the alarm with the key fob it waits 5 seconds and the horn starts beeping. I've unearthed the shock sensor and when I tap it, it has a little red LED which lights up. Closing up the car again, the horn still goes and the light on the sensor doesn't light - I guess that means its not the source of the false alarm.
Both doors and boot/trunk are shut - what else does the alarm monitor?
I just tried removing the shock sensor - just unplugged it from the wiring loom about 3 inches from the sensor. Seems to have cured the problem and the alarm still triggers on the boot opening unexpectedly. I guess this means its the sensor or the wiring loom?
Any help appreciated (by me and the neighbours!) :?:
Jim
PostPosted: Tue Jan 21, 2003 5:09 pm
I'm having the same problems. When I open my hatch the windows roll down, when I turn on the dome light the windows roll up and down. It used to beep the horn for no reason at all. I took the fuse out of the horn. I'm just gonna rewire my car. Get rid of all the alarm problems and start over fresh.
PostPosted: Tue Jan 21, 2003 7:24 pm
Checked the Chassis grounds to the components?
PostPosted: Tue Jan 21, 2003 11:09 pm
Damn Roy, you should retire and stay over here and open one of those Fast And Furious speed shops. 9 time out of 10 your the $h*t on electrical problems.
Could you just picture 4 black Z-28's driving in sync robbing jvc electronics at fast autobahn speeds.
Fast And Furious II.
PostPosted: Tue Jan 21, 2003 11:28 pm
All I do is read repair manuals and look for overlooked stuff. :oops:
