It is currently Sat Sep 12, 2026 12:17 pm
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
PostPosted: Sat Jan 25, 2003 1:29 am
Do you have access to a 0 to 5000 psi guage and fittings. Need to take some pressure readings and compare with what the manuals says.
For the ABS Module , it has to be checked with a TechII scanner for proper functioning. But Ibet it is functioning alright.
PostPosted: Sat Jan 25, 2003 2:06 am
Is that something most mechanic shops would have? if so, Yes I do. good idea I never think of simple stuff like that.....I have never seen brake line pressure getting tested before..Is the pressure gauge specific to testing brake lines?
13.022 @ 105.14
1.869 60'
PostPosted: Sat Jan 25, 2003 2:10 am
I just looked and saw a gauge specific to testing brake system pressure....
0 - 1500 PSI they say it screw right into the caliper....that means in place of the bleeder right?
13.022 @ 105.14
1.869 60'
PostPosted: Sat Jan 25, 2003 2:13 am
Steve most shops have a TecII, and yess it goes right in to the bleeder screw.
PostPosted: Sat Jan 25, 2003 3:18 am
what is Tech II?????? Will a snap on scanner work? thats the only thing I know how to use.
Naw I mean do most shops have a brake pressure gauge
13.022 @ 105.14
1.869 60'
PostPosted: Sat Jan 25, 2003 4:11 am
If it is the Gm version from Snapon it should do it. As for the Brake pressure ,if brakes are a specialty for them then yes they should have one.
PostPosted: Sat Jan 25, 2003 4:34 am
cool, whenever something is screwed up I go over there and they are tossing over wierd new tools for me to use...they never meantioned a pressure tester though.....
13.022 @ 105.14
1.869 60'
PostPosted: Sat Jan 25, 2003 11:15 pm
Hey Steve
Try this for your park brake .
http://csce.uark.edu/~jgbertr/rb/adjparkingbrake.jpg
You can thank Garry for the Link.
PostPosted: Sun Jan 26, 2003 8:19 pm
hehe Shoebox showed me the same diagram......I played that adjustment for two hours but I still cant get "He said POOP" to work back there.
13.022 @ 105.14
1.869 60'
 Post subject: No rear brakes?
PostPosted: Tue Feb 25, 2003 12:37 am
I encountered the same problem after I replaced my rear end. Turned out the rear I bought came out of a wrecked car and the axles were bent. (guy said that there was nothing wrong!) Probally just the flanges were warped, but it was enough to prevent the brakes from locking up. I replaced the axles and all was well. Remember that fishtailing with sticky tires can cause some problems, not that we would do any of that...
