It is currently Sat May 02, 2026 1:52 pm
 Post subject: MAF MALFUNCTION w/ headers?!?!!!?!?!??
PostPosted: Fri Feb 07, 2003 4:45 am
I just put a set of hooker long tubes on my car......they are running completely open....
I started the car and the dummy light came on.....I scanned it and found error #48 MAF system malfunction....I hooked it up to my computer and saw the maf was measuring air just fine.....I check the wiring and its all ok......what could the problem be? :shock:
13.022 @ 105.14
1.869 60'
PostPosted: Fri Feb 07, 2003 4:48 am
I also tried multiple MAFs
13.022 @ 105.14
1.869 60'
PostPosted: Fri Feb 07, 2003 12:15 pm
Close em up and hook up your O2 sensors.
Don't know any more thant that.
PostPosted: Fri Feb 07, 2003 2:59 pm
done and done////
13.022 @ 105.14
1.869 60'
PostPosted: Fri Feb 07, 2003 3:51 pm
What was the out come?
PostPosted: Sat Feb 08, 2003 2:02 am
I found a broken ground wire for something ...I fixed that.....I added 16" header extensions to the long tubes like thunder racing told me to.....still check engine light....now im fonfused....maybe cause I didnt clear the codes? doesn't removing the PCM BAT fuse in the dash clear codes?
13.022 @ 105.14
1.869 60'
PostPosted: Sat Feb 08, 2003 2:17 am
Can you scan it and reset the code?
PostPosted: Sat Feb 08, 2003 9:42 am
yeah I can, just forgot to. I dont have a scanner though.
13.022 @ 105.14
1.869 60'
PostPosted: Sat Feb 08, 2003 10:36 pm
Try and surf around at http://www.bfranker.badz28.com/fbody/guides.htm
There are a couple of other sites on there that may help you.
 Post subject: I am so very very stupid...
PostPosted: Tue Feb 11, 2003 6:50 am
very stupid...The 12volt Power supply pin on the MAF sensor was bent over...
I was just about to tear my whole car apart to inspect the wiring. has the tools out and everything..
What i dont get is how could LT1 Edits free scanning utility be able to tell me how much airflow the motor was getting if the MAF had no power?
13.022 @ 105.14
1.869 60'
