It is currently Sat Jun 27, 2026 11:08 am
 Post subject: C6 "Top Gear" test report ...
PostPosted: Sat Sep 11, 2004 8:30 pm
The new Top Gear issue had a ~10min C6 test in it ... got it on the computer, but would need to scale it down (unless anybody wants to d/l the 120+MB recording) - is anybody interested in watching it?
PostPosted: Sat Sep 11, 2004 8:50 pm
Yeah, I saw that. They were pretty hard on the car I thought! Still had a respectable lap time though. 8)
PostPosted: Sat Sep 11, 2004 8:58 pm
I didn't wonder that the TVR beat it on the Quarter ... IIRC it's lot lighter ... couldn't believe the 911 was way behind the three cars, though ... dunno what 911 they used there ... ;)
PostPosted: Sat Sep 11, 2004 9:20 pm
Might be the one Lupo raced.
Anyways, the vettes lap time was better than the GT3, I find that hard to believe...
PostPosted: Sat Sep 11, 2004 9:55 pm
Hm ... can someone call GM/Opel and have them bring the C6 down to Bitburg for an AutoX run next month? :lol: I'd love to do a lap in it ... and on the quarter ... see how that 400hp LS2 performs ... :)
PostPosted: Sun Sep 12, 2004 10:45 am
The Vette's leaf suspension is top notch when it comes to handling. A bit dated perhaps, but great nonetheless.
PostPosted: Sun Sep 12, 2004 11:00 am
That's one of the points Jeremy Clarkson tried to make fun of - the leaf springs ... but none the less the C6 seems to handle great (which is what the other guy said, too ...)
PostPosted: Sun Sep 19, 2004 1:30 am
why make something expensive and complicated if you don't have to. Leaf springs and a push rod V-8 work very well. The only thing i can say about the Top Gear test driver is "what a candy ass" The wimp complained about the stock shifter being to hard to shift, he should try shifting my Hurst :roll:
The 1/4 mile #s i've seen for a stock C6 are between 12.8 and 13.2. There is a video out of the 13.2 run. As far as I know it was the 1st nonGM person to run a C6 and was a brand new, not broken in car owned by a tuner that will be used for testing. I'm told that they got faster later in the day, but never really pushed to car too much.
This is the best review of the C6 I have seen yet
posted in the AutoX/roadracing section of the corvette forum by AU N EGL
http://forums.corvetteforum.com/showthread.php?t=905738
"Ok guys. Just got back from my test drive of a BLACK with tan C6. ( nice color combination ) standard Supenssion not the Z51 like I thought he said.
First the two vettes I drive routinely are my G/f C5 04 A4 vert 350 hp at the fly( just under 300 at rw ) - bone stock.and Run craps. and my C5 03 MN6 Z51 coupe with 400 rhwp & 425 rwtq with hoosies for the track (DE track car) or Mich PS for the street.
So these above cars are what I am comparing the C6 too. First the stock C6 with the new run craps are much quiter then the run craps on the C5.
I was very impressed with the accerlation of the C6, it was almost as fast as my car too 100 mph. With my MN6 I need to shift from 2 to 3rd at 80 mph 6300 rpm ( my red line is 6650 ). The C6 I could take to 100 mph in 2nd gear at redline. Then in 3rd it pulled very quickly to 125 mph then I had to back down as it was twisty country roads and LEOS like this road too. We continued to cruze about 95-100 on the curves and the car handled extreemly well, nimble, not a lot of steering input and just easly moved from the center line to the right side of the road as right hand curves allowed me to apex. The sales man who was with me ( also a freind ) was very comfortable with me driving 90 too 100 around sweeping corners ( he dosnt know me THAT well ). The new tranny shifts very very smooth and the short shifter is very nice change. The clutch is also stiffer then the C5 clutch.
The longer wheel base but slightly narrower stance works quite well. The car seems to point into corners better then my car or take corners sharper. May also be my 285-30 x18 f vs the C6 245-40x18s ( or what ever it has ) The side to side roll as moderate, I think my G/F 04 vert on stock suppession had less side to side roll. Also the C6 is 2 in taller then her vert. My C5 is dead flat, but then again I have big arz tires to help too.
ON the highway we took the enterence clover leaf corner at .98 Gs ( has g-metter ) and up to 100 again ( talk to me tires ) so we did get a little tire squeel , but great grip and accelation around the corner and then shot out onto the highway. Dang traffic and gravel trucks got in the way However with my minimual spirited driving I did get the oil temp up to 250 real fast ( OIL COOLER PLEASE)
Overall I was very impressed with the handling and extreammly impressed with the acceloration of the stock C6. This will make a great track car.
OK what I did not like. The seats were too hard and even with the lumbar support completly deflated the side bolsters could not wrape up along my sides like the C5 coupes sport seats. Or maybe I just need time to figure that out.
This car has its share of 'test' drives ( wheels showed a fair amount of brake dust ) so I figured that there was enough pad material on the rotors. Well the brakes sucked rocks. Again this was not the drilled and slotted Z51 rotors. Our stock vert stops better, and I have not done a thing to the brakes and we have 2600 miles on the vert. I am also use to the PFC 01s with Castrol SRF fluid on my car. Sooo maybe I am a bit too picky here, but then again. My impression is the brakes need to have the pads and fluid changed after one picks it up from the dealer.
The other thing I did not like was too much electronics. The car must be parked in reverse or it will drain the battery. When we parked the car I left the windows down and when we walked away the FOB locked the car and put the windows up. I dont like that either especillay when you work on the car but for the normal person that is ok.
The one thing the salesman did not like was the ac drain is above the exhaust soo when it drains it drips on to the hot header and steams and or cools soo maybe future cracking??
I aksed him about the C6 ZO6 and he told me what he knew. It will be unvailed in Jan ( we know that) poduction will start in March for May deilveries.that is cool about. ( vert production starts in NOV for Feb delivers ) No they can not take orders for the ZO6 yet. MSRP is $56,000 and change. The ZO6 will be a limited production car of no more then 5000 units, more like 2500 to 3000 units ( may be his maketing ploy ) for 2005. Most likely do to the hand build ZO6 engines. ie quality control for the 480+ HP.
My other thoughts were, If I wanted to get this kind of HP out of my C5 I would have to put in a 427 ci and change the clutch and tranny and T1 suppension and install a roll cage. Heck that is half the price of a C6 ZO6. But if still get the Z06 I still have to put in the cage and the T1 suppenssion, decissions decissions?
So that is what I know guys. Hope it helps a bit
Edit:
I have also drivin a few stock C5 Z06s. The stock C6 has better accerlation the stock C5 ZO6. It is a noticable difference."
PostPosted: Mon Sep 20, 2004 8:44 am
You're right Lancer- they need me to be a test driver on that show. :P
PostPosted: Wed Sep 22, 2004 3:23 pm
I've got the video and I can host it for the weekend if need be. Otherwise every TG is available through BT.
PostPosted: Mon Sep 27, 2004 9:33 pm
Who or what is BT?? British Telecom??
As I have no BBC, I would be interested to get Top Gear on Video.
The best thing about Top Gear is the British Humor. German TV car mags are soo boring :cry:
BTW: I met Jeremy Clarkson on the Nuerburgring on September 19th.
Until November 2004 I had a:
PostPosted: Mon Sep 27, 2004 9:37 pm
Yup, plus they don't really dare to test the cars ... mentioned that before ...
I tried to compress the C6 test, but didn't succeed ... need to re-encode the whole thing somehow ...
PostPosted: Tue Sep 28, 2004 8:05 pm
I heard he was there. Missed it. Super funny guy.
BT is BitTorrent...it's a form of downloading. Really interesting concept. Not unlike next generation US encryption processes. As you can see I was lazy this weekend...didn't do "He said POOP" but but lay on the couch and growl at the dog.
Wrecked the GTO in the rain around a corner this weekend and lost all will at doing anything productive.
Needless to say I won't be racing as the GTO is @ Hollman's in Mainz Kastel awaiting repairs. In a good note...I'm getting Autocross Grills out of the whole deal.
PostPosted: Tue Sep 28, 2004 9:05 pm
Ouch - hope it's not too bad ... ? What happened?
PostPosted: Tue Sep 28, 2004 9:06 pm
I tried to scale down the C6 test, only got it to 80megs ... still a bit big ... got to fiddle around with it a bit ...
PostPosted: Tue Sep 28, 2004 9:35 pm
@ Garry:
a friend is recording Top gear episodes on oldfashioned VHS tape for me. That will do.
But if anyone else is interested: You could put this on CD, put in an envelope and send by mail. You may still find a yellow post box in your town :wink:
@ Sygoat:
I know how it feels. You would give something really valuable to turn back the clock by 5 minutes. It really shattered my confidence.
Users browsing this forum: No registered users and 30 guests
