It is currently Mon Apr 20, 2026 8:31 pm
Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2  Next
 Post subject: What motor is best?
PostPosted: Mon Oct 04, 2004 11:23 am
I spun a bearing this weekend at Bitburg. So out comes 350 #3 and one 305. I have access to a LT1 but I dont know if I should go that route or crate motor. I have TBI rite now what set up would I have to go with to make a LT1 work. I havent been able to find anything on the web that shows what I need to do to make this work and what kind of gains it will give me. I am trying to get my car in 13's as is. I dont want to pull anything out. Can I get this kind of power out of a LT1 with some mods or should I be looking more the lines of 383 stroker. :?:
Owner JZ Customs
Binsfeld GE
PostPosted: Mon Oct 04, 2004 11:49 am
A bolt on LT1 should get you there.
PostPosted: Mon Oct 04, 2004 11:52 am
what type of fuel system will I need to run.
Owner JZ Customs
Binsfeld GE
 Post subject: Re: What motor is best?
PostPosted: Mon Oct 04, 2004 12:17 pm
You could go this route -- http://www.jegs.com/cgi-bin/ncommerce3/ ... rmenbr=361
or
or if you got the money
Best 1/4: 13.587 @100.90mph
PostPosted: Mon Oct 04, 2004 12:53 pm
I like the last one ... ;) :burnout:
PostPosted: Mon Oct 04, 2004 1:43 pm
Thats cool for the crate motors but I want to compare what it would cost to build the LT1 to put in. Im sure I dont want TBI any more so what are my options? How would I make the LT1 work?
Owner JZ Customs
Binsfeld GE
PostPosted: Mon Oct 04, 2004 2:20 pm
I also like that one. Just through it in to see if he would bit on it.
PostPosted: Mon Oct 04, 2004 2:22 pm
Ok you two chip in and I will get it. That not to bad split three ways.
Owner JZ Customs
Binsfeld GE
PostPosted: Mon Oct 04, 2004 2:24 pm
Only if I am the driver!
PostPosted: Mon Oct 04, 2004 2:27 pm
There is no yellow on my car. It takes years of driving to be able to watch movies and race.
Owner JZ Customs
Binsfeld GE
PostPosted: Mon Oct 04, 2004 2:32 pm
Skip the LT1 (sorry Silas and Jason). :) Put in an LS1 and the 13 will be yours. Maybe more. There are a few articles on how to do it in Chevy Hi-Performance.
PostPosted: Mon Oct 04, 2004 2:40 pm
I dont have a LS1. I have a LT1. I am just trying to figure out with all the mods I would have to make to fit a LT1 or LS1 would it be cheaper to just go carburated with a crate motor. The stuff I downloaded about swapping the LT1 dosent have anything on getting rid of my TBI. So I still dont even know how to do it yet. I need a computer and wireing harness for a 93.
Owner JZ Customs
Binsfeld GE
PostPosted: Mon Oct 04, 2004 2:48 pm
I saw an article once on a LT1 that was installed in a 3rd Gen. I think it was in the GM High Tech Performance magazine. One or two issues back. They installed the whole fuel injection system from the LT1 on it. Does the one you have come with the fuel injection system?
PostPosted: Mon Oct 04, 2004 3:00 pm
Its just the motor.
Owner JZ Customs
Binsfeld GE
PostPosted: Mon Oct 04, 2004 5:37 pm
Just the motor? Long block or what?
If you already have the motor, then you should stick with the LT1. Don't listen to the LS1 guys. They'll make you spend too much money.
Use what you have. Get some heads and headers, and a matching cam.
13's shouldn't be hard then
PostPosted: Tue Oct 05, 2004 7:09 am
But I have TBI now what do I do about that?
Owner JZ Customs
Binsfeld GE
PostPosted: Tue Oct 05, 2004 7:25 am
Throw it in the garbage.
PostPosted: Tue Oct 05, 2004 7:30 am
That was already the plan. But what do I replace it with. I just talked to a guy in the states and he said I can even go carburated. I thought I had to put some kind of FI system on it. I am just trying to see what options I have.
Owner JZ Customs
Binsfeld GE
PostPosted: Tue Oct 05, 2004 7:34 am
You can go carburated, but if you run the stock fuel pump(the one in the tank) you will need to put an adjustable pressure regulator between the carb and pump.
PostPosted: Tue Oct 05, 2004 8:05 am
what about just changing the fuel pump out all together. Would I still need a regulator to be able to ajust it?
Owner JZ Customs
Binsfeld GE
Users browsing this forum: No registered users and 21 guests
