It is currently Mon Sep 21, 2026 10:57 am
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
PostPosted: Sat May 14, 2005 1:09 pm
Yeah man, I should have removed that from the get go instead of leaving that on like a dumba$$ ....
The Oillevel sensor was also a dumb move, should have read the manual more carefully.
The waterpump sensor was broke when the engine arrived, the sensor itself is okay but the plastic clamp around it hold the Male connector from the harness was broken so i'll use a new one instead.
The oil pressure sensor was a pain to remove and for some reason that outer shell just came loose, the internals seem still intact and i could hold that shell in place with some glue but i cannot see myself going through all thisrebuild work and then use a 'patched' up sensor, besides they seem fairly priced especially compared to the prices of sensors on European or Japanese cars !
PostPosted: Sat Jun 25, 2005 9:07 am
Dropped off the engine block at the Machine shop, the rebuild has finally started !
PostPosted: Fri Jul 08, 2005 7:53 am
How much they charge for that?
PostPosted: Sat Jul 09, 2005 12:40 am
Don't know that yet, will post it once it gets back (probably around the end of this month).
