It is currently Tue Aug 25, 2026 3:12 pm
 Post subject: hockenheim ring 29jan
PostPosted: Sat Jan 21, 2006 9:32 pm
its official , the ring will be open on 29Jan from 11am til 4pm.
i shall bether if it is dry and above freezing.
PostPosted: Sat Jan 21, 2006 10:42 pm
Me too... :D
PostPosted: Sun Jan 22, 2006 12:02 am
Hm ... do they offer snow-drift in case it snows? ;)
PostPosted: Sun Jan 22, 2006 1:29 am
i'll be in the states :cry:
PostPosted: Sun Jan 22, 2006 12:27 pm
hey somebody gonna let me ride?
the hooptie has falling into disrepair and I don't really care about fixing it cause I leave soon.
PostPosted: Sun Jan 22, 2006 3:30 pm
CandyMan wrote:
Dont forget to shoot some vids for us :D :D :D
:wink:
PostPosted: Sun Jan 22, 2006 6:33 pm
You make it down there i'm sure you be able to get a ride in.
PostPosted: Sun Jan 22, 2006 8:33 pm
that shouldn't be to hard it's not to far. and I still have the family car that drives just fine. just gotta talk the wife into it.
PostPosted: Sun Jan 22, 2006 9:02 pm
"He said doin the nasty" I'll be there. Anybody know what brake pads I shoudl buy to replace the stocker wilwoods I have on my 6pot calipers?
PostPosted: Mon Jan 23, 2006 11:17 am
Sure, I'll be there...
PostPosted: Mon Jan 23, 2006 11:32 am
The Wilwood kits usually come with E-compound pads, which is the pad I've been using for about a year now, it's great for Street/AutoX and the ring, but I'd be Hockenheim will be too much for them. Most of the guys on the Corvette forum swear by the H-compound for heavy track use, but it's not really a daily driver pad, so you'll need to change them out. They'll get you to and from the track just fine, but it'd be best to swap them out. A lot of guys use the Q-compound for street driving and Hs for track days. You should be able to get both in the 7416 shape and stock size rears (don't remember the #)
THe PB-10 is a new compound, it's suposed to perform close to the Es, but with less dust.
you can see all of the pad compounds here
http://brakepads.wilwood.com/01-selection/index.html
PostPosted: Mon Jan 23, 2006 3:24 pm
15H-8114K / 15E-6084K
Is that the right part number for a Superlite 6 Piston Caliper?
PostPosted: Tue Jan 24, 2006 11:43 am
depends on the which SL-6 you've got. Most of the OEM replacement kits sold by Wilwood use the narrower SL-6 which takes a .65" thick pad 7416 shape (http://brakepads.wilwood.com/06-illustrations/pages/7420.html). The wider SL-6R uses a .80" thick, 7420 shape (http://brakepads.wilwood.com/06-illustrations/pages/7416.html).
Those are the right part #s for the 7420 shape, but if you've got the narrow SL-6s, they won't clear your rotors so you'll need the 7416 shape which is part # 15H-8546K & 15H-8546K
If you still have the box, you can match the part # up with this page to see which shape you need, check with the vendor or measure it.
http://brakepads.wilwood.com/04-race/wilwood.html.
PostPosted: Sat Jan 28, 2006 7:39 pm
So, is it snow-drifting in Hockenheim tomorrow? Will the track even be open? Who's coming?
PostPosted: Sat Jan 28, 2006 7:47 pm
i will be there around 11
PostPosted: Sat Jan 28, 2006 10:56 pm
I am not coming anymore have to much $hit to do to get ready to leave.
PostPosted: Sun Jan 29, 2006 4:08 pm
Awesome track conditions if you had AWD. Got stuck three times in the parking lot. :(
PostPosted: Sun Jan 29, 2006 4:12 pm
Ouch ... better there than on the track ... so, how many laps did you dare?
PostPosted: Sun Jan 29, 2006 5:18 pm
The track had about 2 inches of snow on it. Closed ... Had about 40-60 hadr core people wanting to hit it . Just no clean track.
On a side note my exhaust on a throttle blip hits 126 decibel while idling it is 103. :shock:
Just slightly over the limit.
PostPosted: Sun Jan 29, 2006 5:23 pm
Ahem ... lucky you, that it's only SLIGHTLY over ... *gg*
Users browsing this forum: No registered users and 103 guests
