It is currently Mon Aug 24, 2026 4:08 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Mon Feb 13, 2006 9:41 pm
:lol: :ok:
PostPosted: Tue Feb 14, 2006 9:47 am
Roy,
Not a problem, it was the least I could do to help. THANK YOU for the hospitality it was awesome. Didn't make very good time going home but it was a nice drive. I'll PM you with that list of parts and prices for the other stuff we talked about (bolts, gaskets, etc.).
PostPosted: Wed Feb 15, 2006 5:01 pm
Looks like it cracked at the pinion support bearing. Those people must not of supported the case when pressing in the bearing.
PostPosted: Fri Feb 17, 2006 11:55 am
on Ford's the bearing gets pressed in when you tighten the nut on the pinion should have had Ray put the gears in
1.717 60 ft Best 60' 1.705
8.204 1/8 ET
12.441 1254' ET
12.866 1/4 ET
105.88 1/4 MPH Best MPH 107.40
Click here to view free porn videos
PostPosted: Fri Feb 17, 2006 3:16 pm
Ray couldnt have helped this one. The pinion support bearing is pressed into the case from the back side. The company that pressed in this bearing did not support the case and it microcracked as the bearing was seated. 27 years of doing engines, axles and trannies I know a thing or two about them.
PostPosted: Wed Feb 22, 2006 4:58 pm
Roy, Val, what diff did you guys go w/? Tru-Trac, spool, locker, posi? What's the difference between them all and what's the closet thing to a T2R diff. Looks like I'll be biting the bullet and getting me a 9" from Billingsley Racing this spring or fall. :D
PostPosted: Wed Feb 22, 2006 7:52 pm
I went with the locker.
The closest thing to the T2R is the T1 which was designed for AUDI Motorsports. This monster puts the T2R to shame. Its also 900-1100 dollars .
PostPosted: Thu Feb 23, 2006 11:23 am
T1 @ 1100 bucks? Looks like I need to sell some more parts then. I can't settle for nothing less than the T2R equivalent or better. Thanks.
How is your rear coming along?
PostPosted: Thu Feb 23, 2006 6:05 pm
waiting on the mail.
Users browsing this forum: No registered users and 34 guests
