It is currently Sun Oct 18, 2026 3:58 am
 Post subject: Cooler help
PostPosted: Mon Mar 13, 2006 5:31 am
Where is the best place to mount a B&M Supercooler? Looks kinda tight in there
PostPosted: Mon Mar 13, 2006 2:10 pm
I mounted mine on the a/c condensor. Well, it is all attached to the radiator. I recommend you hook up the lines to the cooler and then mount it. It is hard to get to the top line when it is mounted. Make sure you trim the plastic hold downs. The stick through the radiator and can get into the fans. I thought your car was a six speed. Why are you mounting a cooler?
PostPosted: Mon Mar 13, 2006 3:48 pm
A friend of mine here has a auto. If I was mounting a cooler somewhere, it would be on the spoiler :P
