Garry
Post subject: 3rd Brakelight w/ LEDs Posted: Sat May 27, 2006 6:26 pm |
I guess I will take it on to build a LED conversion for the spoiler brake light ... I'm currently trying to pick up a spare light assembly, don't really feel like tearing up my stock one
Anyway, I'm planing on putting something like 12-16, maybe even 20 LEDs in (got to measure/test it out some). But apart from doing a "simple" conversion by just putting them in with resistors, I thought about doing a neat little anim in, by fading out the light from the outside to the inside. Don't know if it'll actually work out as planed, but I recon it should.
Any thoughts on this?
Garry
Post subject: Posted: Sat May 27, 2006 7:22 pm |
Oh, and while I'm at it, I guess I will take a look at some of the miniature lights all around the interior. On my way home from Bitburg I noticed some switches get awfully hot (e.g. fog headlight switch) just from the regular illumination - all I need is a hand full of 680ohm resistors, got a bunch of ultra bright LEDs, that should take care of any heat issue ... see this page for some samples ...
BenZ28
Post subject: Re: 3rd Brakelight w/ LEDs Posted: Mon May 29, 2006 10:26 am |
Garry wrote: I thought about doing a neat little anim in, by fading out the light from the outside to the inside. Don't know if it'll actually work out as planed, but I recon it should.
You could set it up like on the new Mercedes (I think):
Check the travel of the brake pedal (question is how to do that?), the more it is pressed down, the more LEDs are on.
Garry
Post subject: Posted: Mon May 29, 2006 10:59 am |
I recon that is more or less out of the question - that would require more than basic input from the onboard computer system that handles stuff like the ABS ... only other chance would be to continuously read the speed, and if there is a certain percentage in decrease per time interval AND the brake is applied, blink or do whatever ...
For now, all I plan on doing is replacing the brake light assembly without re-building the whole car
Garry
Post subject: Posted: Tue May 30, 2006 5:40 am |
Btw, could use somebody who's in the States ... got a brake light, but the seller only seems to want to ship UPS to the US, not APO let alone international mail ... tnx!
Garry
Post subject: Posted: Sun Jun 04, 2006 2:02 pm |
OK, took a closer look at the light assembly today ... looks like it should be rather easy to build something nice ... also have received some info on accelleration sensors which could be used to detect strong braking, to react by e.g. flashing the brakelight rapidly, only problem is they are relatively expensive (20+€ a piece) ... can get one to experiment with ...
So, I've got three "levels" of implementing this:
* Basic version, LEDs on/off based on the power to the light assembly * Version with fade-out when brake is released * Version with fade-out and emergency flashing if hard braking is sensed
I'll post some details once I get a first version done
Garry
Post subject: Posted: Sun Jun 04, 2006 10:40 pm |
Btw, short of crashing, what are typical braking G values? Stef, any idea?
RTZSS
Post subject: Posted: Mon Jun 05, 2006 8:37 am |
Joined: Sat Nov 23, 2002 11:45 pm Posts: 829 Location: Stuttgart, Germany
Are you looking at making these to sell? I might be interested in the third option.
Garry
Post subject: Posted: Mon Jun 05, 2006 9:00 am |
Let me get one done first
Lancer033
Post subject: Posted: Mon Jun 05, 2006 11:51 am |
Joined: Mon Aug 09, 2004 6:27 pm Posts: 846 Location: Hampton, VA
RTZSS wrote: Are you looking at making these to sell? I might be interested in the third option.
...and how long before you have them available for other models. Specifically Y-bodies. This sounds like a really cool idea if you can make them plug and play. There are a lot of guys on the vette forums that will buy anything new just to have something different so you could probably sell a few hundred easy
Garry
Post subject: Posted: Mon Jun 05, 2006 11:59 am |
Will you be at Bitburg next weekend? I'll take a look at your brake light to see the size of the housing ... electronics won't be too large, but ... I done checked, while the housing is slightly different on the outside between the late 4th gen F-Bodies, the inside is equal, so the same circuit board would fit both Camaro and Firebird (though I will have to look at a high spoiler brake light, which is supposed to be different from the low spoiler version)
Lancer033
Post subject: Posted: Mon Jun 05, 2006 4:24 pm |
Garry
Post subject: Posted: Wed Jun 07, 2006 1:37 pm |
I'm wondering, does anybody know a car that has an LED brake light? I was wondering how many LEDs they have in their third light ... I'm wondering whether 20 (dual row) will be enough ...
RTZSS
Post subject: Posted: Wed Jun 07, 2006 2:29 pm |
Garry
Post subject: Posted: Wed Jun 07, 2006 4:33 pm |
Nice ... 72 LEDs ... OK  sure put enough in there
Post subject: Posted: Wed Jun 07, 2006 7:51 pm |
Lancer033 wrote: doesn't look like i'm going to make it this month, but I won't know for sure until later in the week. Although i think you've pretty much have to take the whole fascia off to get it out. I'll take some measurements tonight.
Its late in the week. Whats the dealio?
Garry
Post subject: Posted: Sun Jul 16, 2006 1:10 pm |
finally got around to opening up the brakelight ... w/ putting 5mm LEDs in the case, I asume anything more than 30 LEDs will be too many ... working on a preliminary circuit setup, I'd prefer not to have two circuit boards in it, so I need some space for the controller chip and additional bits and pieces ...
First pics coming up soon ...
Garry
Post subject: Posted: Mon Aug 14, 2006 8:34 pm |
Anybody got an idea what kind of tech values the LEDs used in comercial LED solutions have? Stef, any idea what Audi uses?
I could get some 3000mCd or 9000mCd white LEDs ...
Garry
Post subject: Posted: Sat Sep 02, 2006 10:24 am |
Well ... others order other - hmmm - Stuff from Thailand, I just got me something, too ...
Bunch of High-Output (11000mCd) LEDs, white and blue (7000mCd, to replace some of the interior, high temperature lighting some time) ... already did a trial run with two white ones behind the brake light encasing ... looking good, should be good to see in day and night ... will start putting it all together, hopefully the basic or V2 version (sequential and/or w/ fadeout) will be up and running for Bitburg next week!
Garry
Post subject: Posted: Thu Sep 07, 2006 8:55 pm |
OK ... just finished the "V2" circuit ... 28 LEDs, 7 groups, with microcontroller ... no G-meter yet, but works nice already ... LEDs come up with some quick on/off for 1s, then do some inside-to-outside sequential lighting three times until all stay on ... subsequent braking with less than ~2s in between just keep all LEDs on ...
Just got to see whether I can actually get it hooked up tomorrow ...  If so, you can take a look at it in Bitburg  Also still have to see how I can glue the whole encasing back together ...
Users browsing this forum: No registered users and 6 guests |
