It is currently Mon Sep 21, 2026 2:29 pm
 Post subject: Cold Air is Good Air
PostPosted: Sun Nov 05, 2006 7:24 pm
Short run on long legs.[/img]
95 Camaro Z28...Stock. ;)
PostPosted: Sun Nov 05, 2006 7:25 pm
Well, that didn't work very well. How do you attach pictures?
PostPosted: Sun Nov 05, 2006 8:14 pm
If it's somewhere on the web already, just add the [ img ] tags, otherwise, use the upload function below to attach single or multiple files ...
PostPosted: Tue Nov 07, 2006 8:47 pm
Lets see if this works. Thanks for the input!
PostPosted: Wed Nov 08, 2006 7:38 pm
Cold air is good. You take that yourelf? The other thing I like about cold air is less bugs on the front of the car!
PostPosted: Sat Nov 11, 2006 5:04 pm
My sister took it when she visited two weeks ago. I have another with the needle a little deeper, but it was taken with film...and 2:73's
There was no way that the car could do this with 3:73's, the top was 135ish and then the OD wouldn't hold the pressure and tried to down shift...SCARY!
Life is better with the 3:42's! The short sprint didn't suffer that much because now she hooks better. I just wish Bitburg was still open and I could get some numbers. I don't even know if I will bring it out next year for fear that I will break it prior to having to ship it.
BTW, when are you going to pick up the exhaust tips?
