Page 1 of 1
[ 15 posts ] |
98 T/A raptor
Post subject: Tranny problems Posted: Tue Jun 19, 2007 6:20 am |
Joined: Tue Aug 17, 2004 11:24 am Posts: 501 Location: sembach germeny
It dosent like going into 4th at high speed like if I am going from the top of third it will go into gear then pop out and wont stay same if I try to down shift on the autobahn doing around 90. Any other time it is fine. SO should I start looking into a rebuild?
_________________ 98 Trans Am
Post subject: Posted: Tue Jun 19, 2007 6:34 am |
572ysc
Post subject: Posted: Tue Jun 19, 2007 6:47 am |
| Senior Member |
Joined: Tue Jun 20, 2006 6:57 pm Posts: 359 Location: Stuttgart, Germany
Hmm did ya check you tranny fluid? Or the kickdown may be of to.
98 T/A raptor
Post subject: Posted: Tue Jun 19, 2007 6:52 am |
Stock shifter.
Post subject: Posted: Tue Jun 19, 2007 9:27 am |
Sometimes its hard to tell , But the 3/4 shiftfork will bend and cause that problem , bit so will a bad 3/4 synchronizer and blocking rings.
AutobahnZ06GT
Post subject: Posted: Mon Jul 02, 2007 8:32 am |
Joined: Fri Apr 04, 2003 6:59 pm Posts: 118 Location: Heidelberg
Like Roy said, I would start with the simple stuff. I would replace the tranny fluid with some synthetic stuff, the PX has Royal Purple. You will need a good pump syphon. I just changed mine this weekend, found out that I was down about a quart, and I had notchy shifting as well beforehand, even after swapping the shifter to the new C6 Z06 shifter, so the notchiness was from the tranny. After swapping the fluid It is easier to shift and I am still evaluating if my tranny should go under the knife. If It does, then I will use one from RPMtranmissions.com. Overall, it is less notchy. Even better fluid is the AMSOL synthetic, which is raved about in the states for the both the racing and street crowd. It will take 2 months to get here via slow boat if yo do order some though.
Good luck,
Nick
_________________ 04 LS6 block, random tech high flow cats, Vararam air intake, LAPD carbon fiber power duct, C6 Z06 shifter, RD motorsports crossbar & 5 Point Harness, GM T1 sway bars, 04 Sachs shocks, Movit brakes, carbon fiber high rise hood, magnason blower
572ysc
Post subject: Posted: Mon Jul 02, 2007 8:40 am |
| Senior Member |
Upps bad mistake I thought he had a auto.
98 T/A raptor
Post subject: Posted: Mon Jul 02, 2007 8:43 am |
Nope the auto is in my 98
NXZ28
Post subject: Posted: Mon Jul 02, 2007 1:32 pm |
Tranny needs to be rebuilt. Sorry to hear it man.
SRZ
Post subject: Posted: Mon Jul 09, 2007 8:29 am |
Chris I sent you a pm. Tell your boy it's doubled since he wasted my time...I didn't have to pull it off in the 1st place.
_________________ The "SRZ" 750rwhp, limited to 55mph flyby's in the US. 02' MY Z06, Cam, LT headers, X-pipe, Breathless CAI, Borla Stinger exh, RSD short shifter, Elite catch can, C6Z susp, CCW classic's 18x10 & 18x12...your normal everyday Z06.
98 T/A raptor
Post subject: Posted: Mon Jul 09, 2007 9:09 am |
I got you sorry again
SRZ
Post subject: Posted: Tue Jul 17, 2007 4:20 pm |
Sup w/ ya boy Chris does he want it or not? Original asking price but he needs to decide or I'm junkin it.
572ysc
Post subject: Posted: Tue Jul 17, 2007 4:29 pm |
| Senior Member |
So did you get it fixed? What are ya gonna do?
98 T/A raptor
Post subject: Posted: Wed Jul 18, 2007 6:12 am |
I have done anything with it because of the accedent. But I will wait till I get back to the states.
sven
Post subject: Posted: Sat Jul 21, 2007 10:01 pm |
Joined: Mon May 13, 2002 2:37 pm Posts: 612 Location: Renton, Washington, United States
Dude before you go for a rebuild when back in the states DO make sure that you have enough fluid... it makes a difference...
_________________ 1999 GM LS-1 T/A
2005 Suzuki GSX-R 1000
Page 1 of 1
[ 15 posts ] |
Users browsing this forum: No registered users and 29 guests |
