It is currently Fri Sep 18, 2026 7:44 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Fri Aug 10, 2007 6:05 pm
and that is the sound of my LS1
http://www.youtube.com/watch?v=fbcRxMOBVcY
PostPosted: Fri Aug 10, 2007 8:40 pm
Sounds pretty good , Once its tuned it will lose alot of its roughness in the idle department.
PostPosted: Fri Aug 10, 2007 9:09 pm
... adding 15% fuel to the tune helped a lot already ... can't do much to it w/o the WBO2 working ...
PostPosted: Sat Aug 11, 2007 1:49 pm
Sounds good to me. How big of cam is in it? BTW, beautiful car Jens.
PostPosted: Sat Aug 11, 2007 2:02 pm
It is a GM Hot Cam w/ LS6 springs LSA 112, 218/227 Duration, 525/525 Lift.
Thank you :D
PostPosted: Sun Aug 12, 2007 7:25 pm
I run the Hot Cam also . I like it because it is valve spring friendly and has a fat midrange .
PostPosted: Sun Aug 12, 2007 7:28 pm
Maybe your tune might be a good starting point for him, also ... !? Same year, same cam ...!?
PostPosted: Sun Aug 12, 2007 7:43 pm
Mine is a 98 with the Hot Cam and 02 LS6 heads and headers.
Jen Your more than welcome to it.
PostPosted: Sun Aug 12, 2007 9:01 pm
sounds great Roy,
i have the hotcam, pacesetter longe tube headers without cats, jpr stage II heads, LS6 intake manifold, K&N FIPK., etc.
and i also have a 98 LS1 with 6 speed manuel transmission.
Maybe i can get your tune, Roy.
