It is currently Mon Aug 24, 2026 12:48 pm
 Post subject: which housing and axle package for LS1 6-speed?
PostPosted: Fri Jan 04, 2008 3:03 pm
One of my friend want a new housing and axle package for his 1999 camaro LS1 with 6-speed. He want 3.77 12 bolt.
What do you think should be the best to buy? Maybe i want to buy at summitracing.com. The car has a little bit over 650 hp.
 Post subject: Re: which housing and axle package for LS1 6-speed?
PostPosted: Fri Jan 04, 2008 3:52 pm
Try Exotic Performance Plus
If your friend is pushing that much PS , Get the Ford Nine inch.
PostPosted: Fri Jan 04, 2008 10:09 pm
nono its called dana 60 or a 14-bolt gm. (hihi).
Yeah the nine inch is definatly a better choice for the stick(t-56) considering the 3,77 ratio.
PostPosted: Sat Jan 05, 2008 2:11 am
Moser 12blt 33spline 3:73 is what Im running in a 98 TA A4
PostPosted: Sat Jan 05, 2008 6:41 am
How about a 12 bolt with 4.56's. Now, those are fun. :)
Really any aftermarket rearend will be good. The Dana 60 seems to be a great way to go, but I only have experience with the Moser 12.
PostPosted: Sat Jan 05, 2008 8:59 am
Ford 9 in - Heaviest, easiest to set up, consumes the most horsepower, very tough
Dana 60 - Mid weight, toughest, middle on consumption of horsepower, harder to set up
12 Bolt - Lighest, least consumption of horsepower, harder to set up, weakest of the three
Depends on what he wants. Prices vary depending on where you get it and if there is a salel going on. Strange does a lot of 12 bolts and Dana's, Moser does the 9 in and 12 bolt, DTS does all three I think.
Hope this helps.
PostPosted: Sat Jan 05, 2008 11:53 am
Yep it all comes down to choices.
PostPosted: Mon Jan 07, 2008 1:47 pm
ok, 9 in Ford Moser.
What means 31-spline, 33-spline, etc.
Is 9in Ford achsle always 3.77?
PostPosted: Tue Jan 08, 2008 4:48 pm
31 spline is the the number splines that engage in the differential and determines the diameter of the axle.
The more splines the bigger the diameter the axle.
a Ford nine inch axle is not always 3.77. The axle ratios can range from 2.20 to 6.50. I have personally counted 50 different axle ratios for the nine inch.
