It is currently Mon Aug 24, 2026 5:49 am
 Post subject: Sea Foam
PostPosted: Sun Feb 17, 2008 6:11 pm
Does anyone know if there are any stores over here, hopefully in the heidelberg area, that sells Seafoam? I would really like to do this to a few of the cars. Thanks guys
Previous Muscle: Dad's 1972 Chevelle SS Stolen in 1990 and a 1971 Chevelle Sold in the 80's
Random vid's of our cars: http://www.youtube.com/user/darksolder
 Post subject: Re: Sea Foam
PostPosted: Sun Feb 17, 2008 8:33 pm
This stuff is in the same catagory as Marvel mystery oil. Pure snake oil.
If you want to make your own Sea Foam heres the recipe.
Ingredients by percentage
Pale oil Probably use transmission fluid (5 parts)
Naptha (3 parts)
Ispropyl alcohol also called IPA (2 parts)
PostPosted: Sun Feb 17, 2008 9:00 pm
So Naptha... not sure what that is... can i get it at an AAFES outlet?
PostPosted: Sun Feb 17, 2008 9:26 pm
Sometimes in the paint and hardware section it is there. You can also find it in the Bau Markts in town
PostPosted: Sun Feb 17, 2008 9:40 pm
That's good to know! i'm going down to a Bau markt tomarrow to get a new tap, works perfectly! And you are sure that this will work just like regular seafoam like on this page http://www.ls1tech.com/forums/showthread.php?t=534376
PostPosted: Mon Feb 18, 2008 8:42 am
Those are the three ingredients that is listed on the MSDS for the product. Nothing special.
Pale oil is a lightweight petroleum based oil.
Naptha is more commonly known as lighter fluid. That is the primary cleaning agent.
ISA is the water remover for the fuel tank.
Personally I would just put a couple cans of Heet in the fuel , And buy either Naptha, Techron 3 or GM Carbon remover and choke the engine out with that.
PostPosted: Mon Feb 18, 2008 3:08 pm
Alright, i just picked up this stuff, i dont know if it's right or not, but this is what i says on the bottle "Brenn-Spiritus" "Brennstoff fur camping und Freizeit" "Universelles reinigungsmittel" and on the back, i think it's the ingredients, says "Ethylalkohol (min. 94 vol. %), vergal-lungsmittel"
PostPosted: Mon Feb 18, 2008 3:57 pm
That is eythy alcohol at about 190 proof. It is not IPA but it will absorb water and and do some cleaning on stuff that will be disolved by EA. Very flammable stuff.
PostPosted: Wed Feb 20, 2008 6:20 am
If you just want to get rid of the water in your tank from the crappy AAFES gas, just pour about half a bottle of gas in your tank before you fill up and it will take care of it. I do it every fall. Something I learned from a marine mechanic that has worked very well over the years.
PostPosted: Wed Feb 20, 2008 6:16 pm
I ordered mine through Midway Auto Supply and they will ship to APO it took about a week. Use the following link.
http://www.midwayautosupply.com/p-29521 ... -sf16.aspx
