jeejee
Post subject: making small progress on my 2009 auto x engine Posted: Mon Jan 19, 2009 11:57 pm |
tried some more tig welding, man this is difficult to do, compared to mig today i did the inlet side..  Shot with N95 8GB at 2009-01-19 i hope my huge 50mm blow of valve is delivered soon so i can find a good location to install it
Post subject: Re: making small progress on my 2009 auto x engine Posted: Tue Jan 20, 2009 6:20 am |
Chevroletfreak
Post subject: Re: making small progress on my 2009 auto x engine Posted: Tue Jan 20, 2009 10:04 am |
| No Life |
Lookin' good. Keep it up.
Post subject: Re: making small progress on my 2009 auto x engine Posted: Wed Jan 21, 2009 11:31 am |
Post subject: Re: making small progress on my 2009 auto x engine Posted: Wed Jan 21, 2009 11:42 am |
jeejee
Post subject: Re: making small progress on my 2009 auto x engine Posted: Wed Jan 21, 2009 12:33 pm |
never seen those before.. but i use some very thin welding gloves when it gets too hot for the most part i use tig for stainless and alu. and stainless conducts heat very poor, so the feeding rod doesn't get very hot and with alu, i need to feed it much faster then stainless so there is less time for the rod to get too warm. does this have a wheel of some sort to feed the rod ? you have a sharp eye with regards to the propane i planned to take full advantage from the 110octane rating from the propane by building a "high" compression (9.5:1) and running high boost, but unfortunately my (german) piston maker didn't build the pistons to my spec and made much lower compression pistons TWICE !  and after several months and much hassle i installed the highest compression set of the 2 (8,2:1) and went along with the build. unfortunately i could allso not use the camshaft i wanted due to the pistons valve pockets where allso not DEEP enough , because of those both things i think i leave 30-50hp unused
Post subject: Re: making small progress on my 2009 auto x engine Posted: Wed Jan 21, 2009 6:17 pm |
jeejee wrote: never seen those before.. does this have a wheel of some sort to feed the rod ? Yes it does and you work it with your index finger .
jeejee
Post subject: Re: making small progress on my 2009 auto x engine Posted: Tue Jan 27, 2009 12:54 pm |
the BOV finally arrived. unfortunately it had 2 aluminum weld on connectors but no stainless, so i had no other choise but to make one myself, it was a bit more work then i anticipated but in the end turned out okay   these silicon hoses are way overpriced, but certainly make things look more professional
Chevroletfreak
Post subject: Re: making small progress on my 2009 auto x engine Posted: Tue Jan 27, 2009 4:10 pm |
| No Life |
Very nice! Where did you get the v-band from?
jeejee
Post subject: Re: making small progress on my 2009 auto x engine Posted: Tue Jan 27, 2009 11:15 pm |
the band itself was included with the blow off valve, unfortunately not the "valve seat part" where the bov is mounted on. nevertheless the v-band can be had from ebay in all kind of configurations
jinstall
Post subject: Re: making small progress on my 2009 auto x engine Posted: Wed Jan 28, 2009 2:50 am |
Joined: Tue Jul 12, 2005 5:08 pm Posts: 942 Location: Fort Bliss, Texas
Funny the LPG was the fisrt thing I notice also.
V-Band? It looks like a normal t-bolt clamp.
The hoses are Samco Sport? I just installed a set on the Jeep from them.
Hey when are you coming tot he US again? I am looking at going to Sebring in March for the 12 hour race.
_________________ 2001 Ford Focus sleeping in Germany 04 Focus ST170 Clone in USA 2010 Renault Clio 1.2 16V in Germany 2013 Focus ST250 in the USA 1st car 77 Camaro Type Lt 5.0 auto
bahndrvr
Post subject: Re: making small progress on my 2009 auto x engine Posted: Wed Jan 28, 2009 7:00 am |
Joined: Sun Sep 23, 2007 10:44 pm Posts: 148 Location: Ft Walton Beach, Florida
jinstall wrote: Funny the LPG was the fisrt thing I notice also.
Hey when are you coming tot he US again? I am looking at going to Sebring in March for the 12 hour race. Hey J, let me know about the Sebring thing, might drive down to it, it's only a few hours past my kids, will look into it:)
_________________ 02 Ford Mustang GT Vert
Chevroletfreak
Post subject: Re: making small progress on my 2009 auto x engine Posted: Wed Jan 28, 2009 10:35 am |
| No Life |
jinstall wrote: V-Band? It looks like a normal t-bolt clamp. The clamp attaching the BOV is a v-band clamp w/ a t-bolt. It is not the flip latch type, but it is a v-band. You can tell from how it mounts.
jeejee
Post subject: Re: making small progress on my 2009 auto x engine Posted: Wed Jan 28, 2009 11:12 am |
jinstall wrote: Hey when are you coming tot he US again? I am looking at going to Sebring in March for the 12 hour race. we plan on visiting the sema show end october / early november if finances (?) allow it, so it still is not set in stone
jinstall
Post subject: Re: making small progress on my 2009 auto x engine Posted: Thu Jan 29, 2009 4:42 am |
OK. Well if I get this job in Montana I am heading there to the mountains. I have had no luck with finding anything back in Germany.
Trever, I am still looking into asking my dad for is camper setup for Sebring.
jeejee
Post subject: Re: making small progress on my 2009 auto x engine Posted: Thu Feb 05, 2009 10:47 am |
i just got the supercharger running, and what was my sursprise ? the cheap knockoff ebay (ss-autochrome/ xs-power) blow off valve had some huge vacuüm leaks inside, so much it would not open untill 4000rpm  contacting the seller several times, gave no replies. I mean how difficult is it to make a working blow off valve ???? but nevertheless i opened it and changed the springrate and was able to fix the vac. leak with some threadlocking compound, is working okay now  i did not install the inlet tube yet, to let it blow out any debris that was left in the intercooler after grinding/ welding it might get around to install it today (weather permitting)
Garry
Post subject: Re: making small progress on my 2009 auto x engine Posted: Thu Feb 05, 2009 11:08 am |
Sounds good ... any idea when it will be ready for racing?
jeejee
Post subject: Re: making small progress on my 2009 auto x engine Posted: Thu Feb 05, 2009 6:32 pm |
well not too long anymore i hope. i did some first test driving today with it. the good news is that it ran very nice for the boost it made in 2nd gear with the long rear axle ratio (3.44:1 )and big 17 inch wheels it starts spinning above 4000rpm bad news is that it only made 0.4-0.5bar at 7000rpm apparently the head flows much better then i thought = so less restriction = less boost tomorrow i will spend some time looking at local scrapyards to see if i can find parts to make a bigger crank pulley
jeejee
Post subject: Re: making small progress on my 2009 auto x engine Posted: Sat Feb 14, 2009 10:35 pm |
Chevroletfreak
Post subject: Re: making small progress on my 2009 auto x engine Posted: Sun Feb 15, 2009 4:55 am |
| No Life |
Nice!
Users browsing this forum: No registered users and 5 guests |
