It is currently Mon Aug 24, 2026 5:16 am
 Post subject: Idler/tensioner pulley questions
PostPosted: Tue Sep 06, 2011 2:09 pm
As I heard those "birds" recently again in the engine compartment :wink: I'm going to replace the 3 idler/tensioner pulleys (2 for the A/C belt and 1 for the main serpentine belt).
The question is:
Is it enough to just change the 3 pulleys or should I better get the whole tensioner with pulleys installed? Does the tensioner get weak after 12 years? What do you think?
Besides, I don't find the 2nd A/C pulley at any part shop, only the one that is part of the tensioner, but not the other one???
 Post subject: Re: Idler/tensioner pulley questions
PostPosted: Tue Sep 06, 2011 7:37 pm
Is it one of these
http://www.gmpartseast.com/chevy/compon ... 1fp87.html
PostPosted: Tue Sep 06, 2011 9:18 pm
Not sure how good your parts supplier is, but a cheaper option might be 1 step smaller belt, depending on total lenght, most of the time 8mm shorther should cure the slip...
PostPosted: Wed Sep 07, 2011 7:37 am
Joeri
I will keep that in mind, when I start raising the rpm and don't want to get a manual adjuster.
PostPosted: Wed Sep 07, 2011 10:37 am
Roy:
Yes I'm talking about "4", "5" and the one on top (that tensions the main belt). What I cannot find anywhere is "4".
EDIT:
Now I've seen the link. So it is a separate part. Thank you Roy! :)
EDIT2:
And what do you think, should I change just the pulleys or also the 2 tensioners?
PostPosted: Wed Sep 07, 2011 5:54 pm
I would just change what is bad.
PostPosted: Thu Sep 08, 2011 8:21 am
I just realize that "4" is the pulley while "5" is the WHOLE tensioner assembly. Hmm, is that pulley on it the same as "4" ???
PostPosted: Thu Sep 08, 2011 8:39 am
I just realize it is. I looked at one of the manufacturer's site (DAYCO) and it's the same part (number) for both A/C idler pulleys.
PostPosted: Thu Sep 08, 2011 4:11 pm
Thats good to know.
PostPosted: Mon Sep 19, 2011 9:31 am
You can try this??
http://www.tickperformance.com/products ... oner-.html
1997 1LE Z28, Powerdyne, Bolt-on, 409RWHP-434RWTQ
1988 IROC 305TPI/A4, Grey Metallic,
PostPosted: Mon Sep 19, 2011 10:48 am
Thank you, I have bought just the pulleys, not the tensioner.
