It is currently Mon Aug 24, 2026 1:40 am
 Post subject: Really, Ford? Are you that cheap?
PostPosted: Wed Dec 28, 2011 1:04 pm
Just read ... the '12 V6 Mustang has a speed limit of 112mph ... according to this article, someone removed the limit, and the drive shaft failed while going 135mph ... for one, I don't really see where the speed should be an issue - rather the torque, and unless they are limiting that, it could even fail at hard launches and the likes ... unless whatever bearing is holding the shaft is the actual cause of the problem ...
 Post subject: Re: Really, Ford? Are you that cheap?
PostPosted: Thu Dec 29, 2011 10:01 am
More than likely the critical speed of the driveline was exceeded for the size of the drive line.
PostPosted: Fri Dec 30, 2011 11:56 am
What is the critical speed for our cars? 300 km/h? :)
PostPosted: Fri Dec 30, 2011 3:14 pm
Ben the critical speed of the driveline refers to the maximum safe rpms that the drive can sustain.
Factors that determine this are :
the length of the driveline
thickness of the metal wall
diameter of the drivline
construction of the driveline ie, steel , aluminum, carbon fiber
The critical speed of the LS1 Alu driveline is around 8500 rpms.
Hope that was a clear explanation.
PostPosted: Mon Jan 02, 2012 10:23 am
Yes, thanks. :)
I was thinking of a stock LS1 Camaro, stock driveshaft etc.
So in this case, 8500 rpms driveline speed should be quite well over 300 km/h car speed.
PostPosted: Mon Jan 02, 2012 1:18 pm
305.7 KPH give or take a couple.
