It is currently Mon Aug 24, 2026 12:57 am
 Post subject: LS6 Intake
PostPosted: Sat Feb 16, 2013 5:23 am
I have been looking on EBAY for an LS6 intake or a similar intake. I saw this intake "97-02 LS1 LS6 Camaro Firebird 96mm Satin Qualifier Intake & Hardware" would this mount on my 98 LS1 engine without changing anything? Thanks in Advance
 Post subject: Re: LS6 Intake
PostPosted: Sun Feb 17, 2013 1:26 pm
I wouldn't get it. Your stock fuel rails won't fit and the quality of the intake looks terrible. I would hold out until I found a used LS6 intake. Make sure you run the numbers off the used LS6 intakes before purchase. The early corvette LS1 intakes looks exactly like an LS6 intake because the EGR port is solid. Have you looked on LS1tech.com under the "Sales" section?
PostPosted: Mon Feb 18, 2013 6:19 am
Thanks for the advice
PostPosted: Mon Feb 18, 2013 10:16 am
LS6 Intake for sale on ebay. Comes complete with intake, injectors, and fuel rail.
http://www.ebay.com/itm/Ls6-Intake-Mani ... es&vxp=mtr
PostPosted: Mon Feb 18, 2013 10:22 am
Would that mount up with any issues?
PostPosted: Mon Feb 18, 2013 10:46 am
It would be a direct bolt on. Also, did you order your headers for the 98-99 model, 01-02 model, or just the race version? The reason I am asking is because The EGR pipe for your model has a tube that runs from the passenger side exhaust to the center/front of the intake. The LS6 intake does not have this port and you would need to block off the tube mount on the header. If you ordered the race version, then no need to block off because the mount is not there to begin with.
PostPosted: Mon Feb 18, 2013 12:01 pm
i ordered the 1 3/4 long tube TSP Headers for 98-02 camaro/firebird. i believe i would need to block it off
PostPosted: Mon Feb 18, 2013 12:20 pm
I just looked at the TSP headers an they do not have the EGR ports. That is good news. Bad news is that it will throw an EGR code in the ECM. We will have to disable the MIL code light for the EGR. Too easy, I did the same to my friends 99 Camaro when he installed MAC headers.
PostPosted: Mon Feb 18, 2013 3:06 pm
Thanks for the info, my name is Joe btw......What do you do in the Army?
PostPosted: Wed Feb 20, 2013 6:02 am
Good to exhange some tech talk with you Joe. I am a Maint Tech.
Don
PostPosted: Thu Feb 21, 2013 4:05 pm
I am a 91Z serving as a First Sergeant in 2-159 ARB...........Nice to meet you
PostPosted: Sat Feb 23, 2013 9:35 am
Awesome. That was my MOS path prior to moving over to the darkside.
PostPosted: Sat Feb 23, 2013 3:42 pm
Our maint tech is CW2 garry Church, not sure if you know him. Ill look you up when i get back
