It is currently Thu Mar 26, 2026 4:00 am
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2
PostPosted: Sun Jun 17, 2001 9:08 pm
Did you drill out the hole in the TB to smooth the idle out? They say it helps alot.
Yep Idrilled it first to 3/16's I believe the hole is originally 5/32'nd of an inch. It helpe a little bit. Now I have drilled it to 13/64'ths and now the car seems to work great . I can tur n the A/c off and on with out the engine dieng . Hot start up is drastically improved.
I am waiting to Find a used HYPER tech To bump my rev and speed limiter up .
PostPosted: Mon Jun 25, 2001 10:22 pm
Hey Roy, I just ordered my Hot Cam, so I'll let ya know when it comes in, if you're still willing to help me out!! ;)
PostPosted: Mon Jun 25, 2001 11:31 pm
Hey Roy,
I'm going to install my cam this weekend, wanna come over and help me too? LOL
I'm sure I'll need the help though ;)
I went to Walmart and bought a bunch of "pen" magnets to hold my lifters just in case!!!
I'll fill you in on the details when she's running again.
Jamey
PostPosted: Tue Jun 26, 2001 5:50 am
Jack and Jamey
No problem I 'll help in any way possible.
PostPosted: Tue Jun 26, 2001 6:25 am
Danke, herr Schlaumeyer!! ;)
PostPosted: Wed Jul 25, 2001 12:43 pm
Where can I get the 1,2,3 on this swap what are the lessons learned do I need any special tools. How long should it take?
PostPosted: Wed Jul 25, 2001 1:26 pm
There is a good cam install write up here...
Cam Install
go to the top left corner a open:
1. Torque Central Folder
2. Installs
3. GM MOds
4. F-Body
then you will see the goldmine...LS1 Cam Install
This is THE best cam install write up out there for the LS1s
Hope it helps,
Jamey
-- Jamey --
PostPosted: Sat Jul 28, 2001 1:44 pm
Thank you I am sure I will use it
PostPosted: Fri Aug 10, 2001 6:04 pm
If you back the idle speed adjustment screw all the way out and put in in from the top, it is MUCH easier to adjust the idle speed by the way.
-- Jamey --
PostPosted: Fri Aug 10, 2001 8:30 pm
great idea and it makes sense.
PostPosted: Tue Sep 18, 2001 10:56 pm
Hi Guys!
Cool place you have here.
Just wanted to drop by after someone told me about this place and saw us mentioned in this thread.
We do have a limited quantity special on the LS1 Hotcam Kit this month:
$313.42 and that includes the LS1 Hotcam Kit + our Kit of gaskets, etc.
Check it out:
http://www.ls1.com/ls1forum/Forum19/HTML/002007.html
I'll be dropping by here more often.
John :)
PostPosted: Wed Sep 19, 2001 5:23 am
That's a pretty sweet deal John. Thanks for letting us know.
PostPosted: Fri Sep 21, 2001 10:26 am
John dont forget about us LT1 guys here:) BTW, offer a military discount, we promise we wont tell anyone! :D Please drop by more often!
 Post subject: LS1 Hotcam is great see a dyno
PostPosted: Mon Oct 15, 2001 1:35 pm
I have a dyno sheet and more for the hotcam
here http://ls1info.com
hotcam,lid,catback
330/330 RWHP/RWTQ
 Post subject: Hotcam Idle fix
PostPosted: Tue Dec 18, 2001 4:30 pm
I have found the with the hotcam and a M6
Throttle blade drilled to 15/64 and .022"
spacer located on top of the idle set
screw.
http://ls1info.com
