Page 1 of 1
[ 20 posts ] |
Randy92Z
Post subject: Where to get gears installed?? Posted: Tue Jun 05, 2001 6:21 pm |
Joined: Sun May 27, 2001 9:24 am Posts: 151 Location: Giebelstadt, Germany
Once I get this 6-speed insalled in my car, I want to put 4.10's out back. Anyone know someone or somewhere I could get this done?? Thanks in advance!!
_________________ Convertible W/L98, TPIS Mini-Ram, TPIS ZZ9 cam, Trick Flow 23* heads, Edelbrock cermaic coated TES, Dynomax high flow cat, Flowmaster Force II exhaust, Fastchips custom chip, March underdrive pulleys, Lakewood LCA's and adj. panhard rod, A/C delete, Smog pump delete, 3.42 rear gears and NOS!!
Robert13p3h
Post subject: Posted: Wed Jun 06, 2001 3:14 am |
Get with the guy doing Silas's car. He told me to he could do it for approx 900dm.
Post subject: Posted: Wed Jun 06, 2001 5:07 am |
Quote: Get with the guy doing Silas's car. He told me to he could do it for approx 900dm.
Either him or Corvette malberg down by where I live.
Randy92Z
Post subject: Posted: Wed Jun 06, 2001 8:37 am |
Hey Roy, could you get in contact with him for me? Or could you possably give me a phone #? Do they speak english? 900DM seems like alot to put in some gears, unless he has the gears and I dont have to give him a set. Thanks fellas!
Post subject: Posted: Wed Jun 06, 2001 10:47 am |
Randy here you go
Corvette Malburg Am Kieselburg 10, 55457 Gensingen Telefon 067275555
They are 3km from the Autobahn cross Bingen on A61. Theremainly corvette people but they wrench any GM.
Robert13p3h
Post subject: Posted: Wed Jun 06, 2001 11:15 am |
900dm is way to much, that is another reason I didnt do it. Especially since you will probably be getting the install kit as well, so they wont need shims or anything, If your T56 came with 3.42s you wouldnt need much besides gears. I dont know what the dm rate is, but anything more than $175-$200 is high.
Randy92Z
Post subject: Posted: Wed Jun 06, 2001 4:43 pm |
Thanks Roy, Ill give them a call.
guerardsgt
Post subject: Is it fully assembled. Posted: Thu Jun 07, 2001 5:32 pm |
Hey randy I can help you out with that. I have to do some stuff to kens camaro from the 19th June till about the 25th. If you want it done soon I'll do it for you. The offers on the table.
Randy92Z
Post subject: Posted: Thu Jun 07, 2001 10:50 pm |
Thanks Ryan!! I proably wont get the gears till next month so, Ill be looking then.
guerardsgt
Post subject: that's ok Posted: Thu Jun 07, 2001 10:57 pm |
If you want just do it yourself. I redid my rearend about a year ago it's not hard. The hardest part is getting the right shims in there.
Randy92Z
Post subject: Posted: Thu Jun 07, 2001 11:16 pm |
Well I know how to do it, but Ive never actually done it before. I guess it cant be too hard.
guerardsgt
Post subject: first time Posted: Thu Jun 07, 2001 11:56 pm |
as long as the gear box is completly put together the only thing you have to do is take the old one out and put the new one in. Also change out the pinion gear that is connected to the drive shaft. And the only thing you have to do to get the right shim. Is try putting in the same combo you had on your old gear box back in. Slap some white out on there rotate it three or four times. Then see were the white mark is if it's not centered then your either to loose or to tight just adjust your shims left or right. If you do it yourself get the shim and bearing kit through jegs or somewhere else. It comes with 3or4 different size shims and you should be good to go. throw some gear oil and posi addative and your ready to roll. That's what I would do spend five hours and save $500.00 can't beat that.
darookie
Post subject: uh oh! Posted: Fri Jun 08, 2001 1:08 am |
Joined: Sun May 27, 2001 9:46 pm Posts: 486 Location: Ft. Lauderdale, FL
I don't know if I would trust this guy! j/k
Robert13p3h
Post subject: Posted: Fri Jun 08, 2001 11:15 am |
isnt there a differance in carrier bearing between the 3.23 and the 3.42? To go to 4.10 you need a 3 series. But he is right, that is pretty much the procedure, I was just worried when I saw your dealing with tolerances between .07 and .03 on the backlash so I decided $180 was worth not burning up the gears, or haveing an air raid siren for a gear set.
guerardsgt
Post subject: there you go Posted: Sun Jun 10, 2001 5:48 pm |
Mike always taking shiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiit you just wait payback is a coming. But good luck on the gears try doing it yourself save money learn something. you can't beat it.
Randy92Z
Post subject: Posted: Sun Jun 10, 2001 10:57 pm |
If I got the gear set it would be for a 3.23 and up carrier, cause thats what I have now. thats what it says in the Summit and Jegs catalog anyways.
Post subject: Posted: Mon Jun 11, 2001 4:23 pm |
Randy here is another place also
Auto Wendt
US Car Specialist
Haup strasse 16
55246 Mainz-Kostheim
Tele 06134-24878
He speaks pretty good english
JackZ28
Post subject: Posted: Mon Jun 11, 2001 9:42 pm |
Randy92Z
Post subject: Posted: Mon Jun 11, 2001 10:13 pm |
Thanks again Roy!
Post subject: Posted: Tue Jun 12, 2001 4:36 am |
Page 1 of 1
[ 20 posts ] |
Users browsing this forum: No registered users and 18 guests |
