Page 1 of 1
[ 7 posts ] |
Daddy
Post subject: Damn Opti! Posted: Sat Sep 03, 2005 9:29 pm |
Well, I got a 0300 code. Multi cylinder mis-fire. I guess that's the Opti.
Any advice? I'm gonna clean the MAF and see what that does.
Miss you guys
johnnyv89
Post subject: Posted: Sat Sep 03, 2005 9:37 pm |
Joined: Thu Jan 01, 2004 6:04 pm Posts: 229 Location: Vogelweh, Germany
Sounds expensive, good luck. my check engine light came on the day before I left Germany. I have to wait till October before I can find out what it is.
NXZ28
Post subject: Re: Damn Opti! Posted: Sun Sep 04, 2005 2:06 am |
Daddy wrote: Well, I got a 0300 code. Multi cylinder mis-fire. I guess that's the Opti. Any advice? I'm gonna clean the MAF and see what that does. Miss you guys
Has the Opti ever been replaced? I would say it may just be the rotor but you still have to tear it down to check it. I would just replace the whole opti it if I tore it down that far. MSD now sells a cap and rotor for it. Good luck.
Daddy
Post subject: Posted: Sun Sep 04, 2005 3:43 pm |
I was thinking about that Dyna spark.
How you doin dude? Still in the sand box? I'll be back there in Oct
NXZ28
Post subject: Posted: Sun Sep 04, 2005 4:00 pm |
I am doing fine. I won't be home until mid-November. How long are you going to be back for? Later,
Don
Daddy
Post subject: Posted: Mon Sep 05, 2005 12:53 am |
NXZ28
Post subject: Posted: Mon Sep 05, 2005 5:38 am |
Hey, I forgot to tell you to check all your plug wires and make sure you didn't burn one. Also, pull the coil wire off and look at the connections. My black car would not even run one day and I pulled the coil wire off. The connection was green. So I cleaned it up and I ran perfect. I would have to check it about once a year.
Page 1 of 1
[ 7 posts ] |
Users browsing this forum: No registered users and 61 guests |
